Help....with leveling
Forum topic by Headbone posted 07-13-2014 03:25 PM 1028 views 0 times favorited 9 replies Add to Favorites Watch
View Headbone's profile
Headbone
11 posts in 1428 days
07-13-2014 03:25 PM
Topic tags/keywords: question maple sander planer refurbishing traditional
I am refinishing an older maple pastry board for my wife. The board itself is in good condition however it does have a wobble. I am looking for advice on leveling it out. I am considering planing or sanding down the high points.
9 replies so far
View Bill White's profile
Bill White
4929 posts in 3957 days
#1 posted 07-13-2014 03:43 PM
How far “off” is the board?
Bill
-- bill@magraphics.us
Headbone
#2 posted 07-13-2014 04:06 PM
3/8 inch at most.
View mahdee's profile
mahdee
3883 posts in 1765 days
#3 posted 07-13-2014 04:11 PM
You can always use the low point as a reference and run it through the table saw.
-- earthartandfoods.com
View distrbd's profile
distrbd
2252 posts in 2443 days
#4 posted 07-13-2014 04:12 PM
I wonder if cutting the board into 2 or 3 strips (then joint and plane each) ,and gluing them up would work?
You will waste 1/8” 0r 1/4” from the width. that would be the only drawback I can see.
-- Ken from Ontario, Canada
View MT_Stringer's profile
MT_Stringer
3168 posts in 3228 days
#5 posted 07-13-2014 04:49 PM
With those two edges in the way, I don’t see a good solution. I have seen router sleds that could be used to plane the surface flat , but you would still have to deal with the area of the board adjacent to the two ledges.
How big is the board?
Is there any way to remove the two ledges?
View Clint Searl's profile
Clint Searl
1533 posts in 2358 days
#6 posted 07-13-2014 04:54 PM
Put three feet under it.
Headbone
#7 posted 07-13-2014 05:26 PM
Ledges pretty well have to stay. If I can’t get it to level out, I might just glue a shim to the bottom side to make up for the gap.
View timbertailor's profile
timbertailor
1594 posts in 1421 days
#8 posted 07-14-2014 03:32 AM
Edge mold with hardwood and biscuit joint it all the way around. Clamp to a flat surface while gluing.
That usually takes the bow out of it. And if you are really sneaky, make the edge band just a bit taller than the board and create a foot all the way around that IS flat.
View Tootles's profile
Tootles
808 posts in 2499 days
#9 posted 07-14-2014 07:01 AM
You could try a planing jig for a router. Just google the phrase “flatten board with router” and you will see a number of examples such as this and a number of Youtube videos as well.
-- I may have lost my marbles, but I still have my love of woodworking
