Resawing
Forum topic by Deela40 posted 07-13-2014 01:17 PM 1769 views 1 time favorited 18 replies Add to Favorites Watch
View Deela40's profile
Deela40
105 posts in 3052 days
07-13-2014 01:17 PM
Topic tags/keywords: ash bandsaw question resawing
I was using my bandsaw to resaw piece of ash. This particular piece, pre-cut, is 6” x 3.5” 1-1/4”. Once all the way through the two pieces bowed.
Any ideas of why this happened?
-- www.heritageclothespins.com
18 replies so far
View Clint Searl's profile
Clint Searl
1533 posts in 2325 days
#1 posted 07-13-2014 01:53 PM
Isn’t it obvious?
Deela40
#2 posted 07-13-2014 02:00 PM
Clint,
This is the first time I have tried to resaw anything on my bandsaw so I am not very familiar with all the issues with this process. As a result, it is not obvious to me.
View Wayno1's profile
Wayno1
12 posts in 1387 days
#3 posted 07-13-2014 02:22 PM
I am having moisture issues as we’ll at this time. I could be off base,but it looks like the “shell” is dryer than the “core”
Hopefully someone can post and help us both
View Chris Cook's profile
Chris Cook
322 posts in 2245 days
#4 posted 07-13-2014 02:28 PM
wayno nailed it, you released the balance of stress in this piece. The cut of the wood determines when this can happen.
-- Chris, "all we are is sawdust in the dust collector""
TheWoodenOyster
1313 posts in 1899 days
#5 posted 07-14-2014 03:02 AM
There is no reason that would be obvious to anyone who hadn’t resawed before. Don’t feel bad. Good job responding like an adult.
To answer the question, there are internal stresses that are released anytime you cut up a piece of lumber, especially when you do an operation like resawing. As soon as you are done cutting, the board in a sense releases a bunch of tension and can bow itself, or for that matter unbow itself. There is nothing weird or strange about what happened there. That is pretty common with resawing. One thing to consider is waiting at least a day to actually work with resawn pieces as they can warp and/or bow a decent amount over the first 24 hours when they are cut. Let them move around for a day or two and then joint, plane, etc. You could even wait a week or so if you have the time.
As those above said, it could also have something to do with moisture, but I have always broadly categorized it as internal stress. It is possible that the internal stress is being caused by moisture.
Hope that helps. Good Luck
-- The Wood Is Your Oyster
10252 posts in 3612 days
#6 posted 07-14-2014 03:30 AM
It’s fairly common. Case hardening can cause that too
I think.
This type of distortion is one reason I feel all the hubbub
about 12” and higher resaw capacity is a bit much. For
thin woods like veneers and guitar plates, I guess 9”
or 10” is good if the source board is wide enough, but
for general resawing for furniture making I find setups
of less than 6” go faster, are more pleasant to feed,
less prone to compound (wedge shaped cuts) error
and don’t often cup so much you have to rip the
resawn board in half and reglue anyway to get a
flat board in a thickness close to what you were after.
You may be able to flatten those out a bit by stickering
them with weight on top, or clamping flat in such a way
that air can circulate around the faces of the boards.
View pintodeluxe's profile
pintodeluxe
5620 posts in 2777 days
#7 posted 07-14-2014 04:51 AM
It is reaction wood. Every tree has some, and you will find a lot of it near the base of the trunk, or where branches exit the trunk. Basically there is tension built into the structure of the tree to resist gravity, wind, slopes etc. When we cut pieces free, the tension is released.
Green or improperly dried lumber is more prone to these problems.
Flatsawn lumber is more likely to cup over time than quartersawn lumber.
Good luck with it.
View Jim Finn's profile
Jim Finn
2647 posts in 2886 days
#8 posted 07-14-2014 12:35 PM
Good quote: “There is no reason that would be obvious to anyone who hadn’t resawed before. Don’t feel bad. Good job responding like an adult”.//// ////// I have had this problem when resawing oak that I stored outside. Bringing it inside to the workshop for a few days helps to acclimate the wood to the shop and this problem is lessened.
-- Website is https://craftingcouple.com/
View CharlesNeil's profile
CharlesNeil
2385 posts in 3835 days
#9 posted 07-14-2014 12:58 PM
The issue here is 2 fold, one you have released stress as stated, second no matter how dry wood is, its never as dry on the inside as the out side, so when you open it up, the newly exposed surface is going to dry out and as it does it shrinks causing it to cup. A trick I use is to lightly dampen the out side, then after its resawn clamp it , back to back with the new surfaces on the out side and let it acclimate a few days, makes a world of difference. You can probably also put these out in the sun for a little bit , with the OUT SIDE up , this will cause the out side to dry a little more and often it will reverse a cup, the key is to get the moisture in balance. Just be careful I have seen the sun totally reverse a cup .
View Redoak49's profile
Redoak49
3193 posts in 1953 days
#10 posted 07-14-2014 01:40 PM
As all of the above has said, it is really an expected reaction. Also, when you have the rings of the tree almost parallel to the surface, you can expect some bowing of the boards. If the wood is not completely dry all the way through, the bowing will probably get worse.
Plain sawn wood like this does have the tendency to bow while quartersawn wood will bow much less.
Deela40
#11 posted 07-14-2014 01:53 PM
Thank you all for the informative responses. I have clamped the two pieces together and will see if this improves the bowing after a few days.
View gfadvm's profile
gfadvm
14940 posts in 2654 days
#12 posted 07-15-2014 01:05 AM
Charles Neil nailed it (as usual). I would add that certain woods (pecan) is especially prone to cupping when being dried. Even when properly stacked and stickered with weight on the stack. I actually have more trouble with the boards near the center of the log (quarter sawn with pith down their center) cupping than the outer flat sawn boards.
View bigblockyeti's profile
bigblockyeti
5092 posts in 1685 days
#13 posted 07-15-2014 02:14 AM
It’s case hardened as previously mentioned. It wasn’t dried correctly in order to prevent this.
Deela40
#14 posted 07-15-2014 11:29 AM
Is there any way to avoid this? If there is an issue with the drying process, how can I tell before I make the purchase?
bigblockyeti
#15 posted 07-15-2014 12:54 PM
Taking a section from the end and cutting a section from the middle ~1/3 of the width, forming two prongs will revel the presence and severity of any case hardening. Hopefully the picture can explain it better than I can.
