How thin a table saw cut are you comfortable making?
Forum topic by LiveEdge posted 07-11-2014 10:52 PM 1837 views 0 times favorited 27 replies Add to Favorites Watch
View LiveEdge's profile
LiveEdge
598 posts in 1861 days
07-11-2014 10:52 PM
I’m curious how people feel about the distance between the blade and the fence and what the minimum they would consider doing would be?
My push stick is a large plastic thing and is probably 1/2” wide. I have generally felt comfortable doing a 3/4” rip, but it does feel like the push stick is close to the blade. I once nicked the push stick on a different type of cut and it, of course, gave me quite a start and took a small chunk out of the stick.
Should I stop doing this and what would the alternative method be? (Don’t assume I can just put the 3/4” on the other side of the blade. Let’s say the wood is 1 1/2 inches thick and I’m trying to rip in half.)
27 replies so far
View johnstoneb's profile
johnstoneb
3072 posts in 2413 days
#1 posted 07-11-2014 10:54 PM
I have ripped as thin as 1/8” and felt safe doing it.
-- Bruce, Boise, ID
LiveEdge
#2 posted 07-11-2014 10:57 PM
Just to be clear, you have 1/8” between the blade and the fence? How do you get the stock through? Do you grab it on the other end?
View AandCstyle's profile
AandCstyle
3185 posts in 2498 days
#3 posted 07-11-2014 10:58 PM
Rip half the length, turn the TS off, flip the stock end for end and finish the rip.
-- Art
View NiteWalker's profile
NiteWalker
2738 posts in 2818 days
#4 posted 07-12-2014 03:01 AM
I rip 1/8” strips pretty frequently. That is 1/8” between the fence and blade. A riving knife and push shoe make it as safe as any other cut. Since my push shoes are 3/4” thick I end up with a sacrificial one since it gets cut into.
View paxorion's profile
paxorion
1107 posts in 2286 days
#5 posted 07-12-2014 03:12 AM
I’ve done down to ~1/4” and I currently use my Grr Ripper. Before that, I treated push sticks (shoe style) as sacrificial to perform the rip.
-- paxorion
View CharlesA's profile
CharlesA
3361 posts in 2038 days
#6 posted 07-12-2014 03:15 AM
Grr-ripper is great for 1/4” and even for 1/8” if you buy the thinner leg. Remarkably easy.
View cutworm's profile
cutworm
1075 posts in 3034 days
#7 posted 07-12-2014 04:38 AM
Funny you should ask. Making shutter louvers. Got careless around 75 or 80: Ouch.
-- Steve - "Never Give Up"
View emart's profile
emart
445 posts in 2869 days
#8 posted 07-12-2014 04:48 AM
I tend to use push sticks as well as other scrap lumber to help keep the wood against the fence since often the wood I’m ripping Isn’t very straight. The closest I have ripped is about 1/4” and since I make my own push sticks (with shark faces drawn on them) I make sure they are high enough to keep me well away from the blade. That being said I wouldnt mind making some sort of jig to do this more safely.
-- tools are only as good as the hands that hold them https://www.custommade.com/by/emeraldcrafts/
NiteWalker
#9 posted 07-12-2014 05:05 AM
Steve, I hope your healing is speedy and as painless as possible with an injury like that.
How did you get careless? How did your thumb come into contact with the blade?
cutworm
#10 posted 07-12-2014 05:29 AM
Not paying attention. I had to cut about 120 or so louvers. After about 75 I started losing focus. Thumb is doing well. Pride isn’t. Here is the first set. All cuts are made for the remaining 4 sets.
View Lumberpunk's profile
Lumberpunk
334 posts in 2578 days
#11 posted 07-12-2014 05:32 AM
Sacrificial push stick… backsaw style. 1/8th
-- If someone tells you you have enough tools and don't need any more, stop talking to them, you don't need that kind of negativity in your life.
View NormG's profile
NormG
6378 posts in 3245 days
#12 posted 07-12-2014 05:50 AM
When I get that close I use wood push sticks, blade goes through them and I just make another one when needed
-- Norman - I never never make a mistake, I just change the design.
View Dunshuvlin's profile
Dunshuvlin
24 posts in 2297 days
#13 posted 07-12-2014 06:06 AM
I regularly cut to 3mm (yes we are metric over here☺) for laminated arches. A wooden, sacrificial push stick is essential if you want to keep your blood on the inside.
-- Dunshuvlin, Europe
View squazo's profile
squazo
120 posts in 1886 days
#14 posted 07-12-2014 06:12 AM
i got some 128 stuff, granted i thought it would all be dust but i did accurately repeat it
NiteWalker
#15 posted 07-12-2014 07:33 AM
Not paying attention. I had to cut about 120 or so louvers. After about 75 I started losing focus. Thumb is doing well. Pride isn t. Here is the first set. All cuts are made for the remaining 4 sets.
- cutworm
If it’s any condolence, the shutters look great.
