45 degree cuts
« back to Joinery forum
Forum topic by LueyD posted 07-11-2014 05:53 PM 1025 views 0 times favorited 6 replies Add to Favorites Watch
View LueyD's profile
LueyD
20 posts in 1436 days
07-11-2014 05:53 PM
Topic tags/keywords: question pine tablesaw joining
How do you cut a 45 degree using rounded material on a table saw?
I am trying to miter this piece of wood (one side that has a curved surface). My problem is how would I measure the wood to be at the end using the 45 degree angle. I realize now that I should have just cut the 45 degrees at the beginning instead of pre cutting the wood. Here is the picture of my saw as well as the piece of wood I am attempting to use.
Any assistance would be greatly appreciated. Thank you
LueyD
-- LueyD
View Richard's profile
Richard
1916 posts in 2689 days
#1 posted 07-11-2014 06:04 PM
I would just sneak up on it as they say , start a little short of gitting the full 45 on it and just keep moveing the fence a little bit more to the left for each cut until you get the 45 at the very edge. Most likely a better way to do it but if I was in a hurry thats how I would do it.
View Gary's profile
Gary
9331 posts in 3431 days
#2 posted 07-11-2014 06:20 PM
a quickie note…. If you measure the thickness of the board and go back that far from the front, you will have a 45
If it’s 3/4 thick, measure back 3/4 from the front.
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2368 days
#3 posted 07-11-2014 06:21 PM
I would ditch the fence and attach a backer board to my miter gauge. Run that over the blade without the workpiece to create a kerf. Mark the cut line on the workpiece, then line it up with the kerf in the backer board. If you have multiple ones to do, attach a stop block to the miter gauge board.
View lew's profile
lew
12060 posts in 3753 days
#4 posted 07-11-2014 06:22 PM
A 45° degree triangle has equal length sides (A & B). If you measure the thickness at the “high point” then measure back from the square end the same distance. Draw a line from that point to the edge and you should have the correct distance. Just to be safe, cut a little proud and do what Richard said. Also, be careful of kickback cuase it looks like you’ll be hand feeding the piece thru the blade.
View Monte Pittman's profile
Monte Pittman
29226 posts in 2336 days
#5 posted 07-11-2014 06:28 PM
This is where the miter fence comes in. Holding it from the side and not the end.
Richard
#6 posted 07-11-2014 06:44 PM
See I told you there was an easy way to do it. This was taught to me way back in High School but I just forgot it in the long absence from woodworking , Now if I can just tuck this into my brain and not forget where I put it this time.
