Glueing long miters
« back to Joinery forum
Forum topic by lateralus819 posted 07-11-2014 02:32 AM 1121 views 0 times favorited 9 replies Add to Favorites Watch
View lateralus819's profile
lateralus819
2241 posts in 1890 days
07-11-2014 02:32 AM
Hello looking for some tips here.
I’ve some miters i need to glue, 8/4 thick x 5” wide x 36” long.
Pretty beefy.
Only two sides and one end. Any tips for a seemless joint? I’ve tried the blue tape method, and it works okay. Just looking for maybe that little extra help?
9 replies so far
View Don W's profile
Don W
18717 posts in 2568 days
#1 posted 07-11-2014 07:12 PM
I don’t understand what you’re asking. If its how to get rid of glue squeeze out, use the tape, glue it, and then wipe the excess off with a damp cloth or paper towel.
If that’s not what you’re asking, rephrase the question.
View pintodeluxe's profile
pintodeluxe
5662 posts in 2813 days
#2 posted 07-11-2014 07:24 PM
Assuming you mean a 36” long miter joint, I have had pretty good luck with biscuits. You can glue and clamp the joints with miter clamps. Otherwise, a few brad nails can do the trick until the glue dries.
Burnishing the joint with a screwdriver shaft can help hide any imperfections in the long miter.
Don W
#3 posted 07-11-2014 08:25 PM
ratchet strap.
View HerbC's profile
HerbC
1756 posts in 2860 days
#4 posted 07-12-2014 04:42 PM
To strengthen the joint and simplify the clamping, try a lock miter router bit. If you’re going that route, try Infinity Tools Lock Miter Master which will simplify setup.
Good Luck!
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View bigblockyeti's profile
bigblockyeti
5121 posts in 1721 days
#5 posted 07-12-2014 05:26 PM
Like Willie, I like using biscuits on longer miters; 1 in any miter longer than 3 inches, two 8 inches and slightly beyond, anything with really significant length; one every 6 to 8 inches.
View AlaskaGuy's profile
AlaskaGuy
4140 posts in 2309 days
#6 posted 07-12-2014 05:58 PM
To strengthen the joint and simplify the clamping, try a lock miter router bit. If you re going that route, try Infinity Tools Lock Miter Master which will simplify setup.
Good Luck!
Be Careful!
Herb
- HerbC
If I read his post correct he’s using 2” thick stock. I don’t know of a lock miter cutter that will cut that thick.
For the OP, not sure what “Only two sides and one end” means.
View Gary's profile
Gary
9331 posts in 3433 days
#7 posted 07-12-2014 07:57 PM
A picture of what you have would really help
HerbC
#8 posted 07-12-2014 08:27 PM
If I read his post correct he s using 2” thick stock. I don t know of a lock miter cutter that will cut that thick.
- AlaskaGuy
Good catch AlaskaGuy…
Herb
View NoThanks's profile
NoThanks
798 posts in 1529 days
#9 posted 07-12-2014 10:02 PM
I don’t know whats wrong with the tape method. It works great if you do it right and have good cuts to start with. Use regular masking tape, 1 1/2 wide stuff.
Place the first layer right over the center of the seam.
Place the second layer about 1/4 ” over the seam on the right side,
the 3rd layer about 1/4” over the seam on the left side,
then apply another last layer over the center of the seam, same as the first layer.
This will clamp it as tight as anything.
The more layers of tape the more pressure it adds at the seam.
-- Because I'm gone, that's why!
