Looking for a Specific Router Bit
Forum topic by JamesAZ posted 07-10-2014 09:53 PM 1301 views 0 times favorited 10 replies Add to Favorites Watch
View JamesAZ's profile
JamesAZ
11 posts in 2356 days
07-10-2014 09:53 PM
Topic tags/keywords: router bit
Need help finding a Router Bit that will cut the edge showing in attached image…
Thanks for you help… James
10 replies so far
View DaleM's profile
DaleM
958 posts in 3405 days
#1 posted 07-11-2014 01:05 AM
I’m not sure what the thickness of the wood is, but I found a bit that might work. You would have to raise the bit to the right height to just get the right portion on the wood, that is, if it’s even the right size for the thickness of wood you are using. I circled it in red. This is from Whiteside’s catalog.
-- Dale Manning, Carthage, NY
JamesAZ
#2 posted 07-11-2014 06:39 AM
Approximate ¾” Thick wood – Deepest radius about 5/16”
DaleM
#3 posted 07-11-2014 09:00 PM
It doesn’t look like the bit I found above will work for 3/4. I think it would give the profile you are looking for, but only on 4/4.
JamesAZ
#4 posted 07-11-2014 09:09 PM
Thanks for looking…
It doesn t look like the bit I found above will work for 3/4. I think it would give the profile you are looking for, but only on 4/4.
- DaleM
View woodman71's profile
woodman71
162 posts in 3346 days
#5 posted 07-11-2014 10:45 PM
I’m take a shot in the dark here James but I wonder if this might have been made with table saw molding head cutter.
View dawsonbob's profile
dawsonbob
2881 posts in 1777 days
#6 posted 07-11-2014 11:00 PM
Shaper bit, perhaps?
-- Mistakes are what pave the road to perfection
View Tootles's profile
Tootles
808 posts in 2523 days
#7 posted 07-12-2014 06:53 AM
What you are looking for may be called a “table edge bit” – but there are lots of different styles of table edge bits, so it is not quite so straight forward. Do a quick Google image search to see what Imean.
I have a catalogue from an Australian company called Carbitool. It has a bit that is close to what you want but, as you can see, not the right size. They do claim that they can make special bits to any size or detail – please furnish a wood sample, drawing or dimensioned sketch when ordering. Of course, I am sure there would be companies in the US that might offer a similar service.
Good luck finding what you are after
-- I may have lost my marbles, but I still have my love of woodworking
View Loren's profile
10476 posts in 3669 days
#8 posted 07-12-2014 07:17 AM
#9 posted 07-12-2014 07:18 AM
View Nubsnstubs's profile
Nubsnstubs
1296 posts in 1752 days
#10 posted 07-12-2014 01:14 PM
If you’re trying to duplicate that profile, it looks like you’re going to be making several passes with creative holding techniques….. If it’s been done once, it can be duplicated. Study it closely, and check you cutter arsenal and try it.
I think a lot of people don’t know that you don’t really need to use the whole cutting edge of any of your shaping tools. A combinatin of partial profiles can give you custom shapes…. ......... Jerry (in Tucson)
