SteelCity 35990C Issues
Forum topic by Mark2457 posted 07-10-2014 08:51 PM 1156 views 0 times favorited 21 replies Add to Favorites Watch
View Mark2457's profile
Mark2457
49 posts in 1487 days
07-10-2014 08:51 PM
Topic tags/keywords: tablesaw question
Hi All
This is my first decent saw. Had a well-used BT3000 previously. I bought the 35990C a few months ago and my wife bought me an Incra fence system for a birthday gift.
I finally got it all setup last week
I find the anti kickback pawls terrible. They just fly off all the time. Of course I could be attaching it wrong as the manual is god awful. Surely they can a afford a few hundred bucks for an English speaker. I push the “bar” into the elongated slot, rotate the front down toward the blade and tighten the thumbscrew as tight as I can. As soon as I put a piece of lumber through it, they just fly off
Finally, it seems underpowered. I was ripping about 1/4 inch off a 2-inch thick piece of oak and the blade frequently stops completely. I don’t feel I was feeding too fast. (Naturally, I replaced the crappy supplied blade—with a diablo). It’s wired to a dedicated 20A circuit. (I’ll be switching over to 240v soon, as I’m running 50A to garage at weekend, but I don’t think this will help)
Anyone else having these issues?
Regards
Mark
21 replies so far
View SASmith               's profile
SASmith
1850 posts in 2890 days
#1 posted 07-10-2014 08:58 PM
Are you sure that it is a (under)power issue and not the belt slipping?
-- Scott Smith, Southern Illinois
View jonah's profile
jonah
1572 posts in 3201 days
#2 posted 07-10-2014 09:10 PM
Either that or a misaligned fence. Even a relatively modest 32nd of an inch toe-in at the back of the fence can make it virtually impossible to push a piece through.
Not to mention insanely dangerous.
Mark2457
#3 posted 07-10-2014 09:14 PM
- SASmith
I hear a slight squeal when the motor starts up, but it definitely sounds like the motor stopped when the blade stopped. Unfortunately, I don’t feel safe leaning over to look in side the base while holding a piece of stuck wood :-)
Mark2457
#4 posted 07-10-2014 09:15 PM
- jonah
I did check the blade to miter slot and miter slot to fence alignment. It’s within a few 1/1000’s. If that was the issue, surely it would do it on thin stock too?
View knotscott's profile
knotscott
7871 posts in 3278 days
#5 posted 07-10-2014 09:33 PM
50T is a lot for 2” thick material. Do you have a 24T rip blade?
I’d also check the belt tension, belt placement on the pulleys, and the pulley alignment with each other.
View NiteWalker's profile
NiteWalker
2736 posts in 2480 days
#6 posted 07-10-2014 09:50 PM
Belt tension is where I’d be looking first.
Mark2457
#7 posted 07-10-2014 10:14 PM
I d also check the belt tension, belt placement on the pulleys, and the pulley alignment with each other.
- knotscott
Currently have a 80T blade. It’s probably less than 1/8th. The amount coming off on the left of the blade is wafer thin. There’s nothing in the user guide about belt tensioning and I wouldn’t know what’s right (yet). If it was the belt, wouldn’t I hear the motor still running?
View retfr8flyr's profile
retfr8flyr
380 posts in 1572 days
#8 posted 07-10-2014 10:23 PM
You’re cutting 2 inch oak with an 80 tooth blade and 1½ HP saw? It’s no wonder that it’s stopping. Get a decent 24 tooth rip blade and see how it does.
-- Earl
knotscott
#9 posted 07-10-2014 10:50 PM
- knotscott
Currently have a 80T blade. It s probably less than 1/8th. The amount coming off on the left of the blade is wafer thin. There s nothing in the user guide about belt tensioning and I wouldn t know what s right (yet). If it was the belt, wouldn t I hear the motor still running?
- Mark2457
Even worse….by a lot! Ripping 2” oak with an 80T fine crosscut/plywood blade is total mismatch for the task. Most saws are under powered for that. Try a 24T thin kerf blade like Earl suggested. If you’re still having trouble, then something is wrong with the saw.
View Ocelot's profile
Ocelot
1882 posts in 2541 days
#10 posted 07-11-2014 12:35 AM
Fewer teeth is what you need. +1 for knotscott and Earl.
A Freud Thin Kerf Rip blade will make an amazing difference.
I use both
LM75R010 (30 tooth) and LU87R010 (24 tooth – flat tooth, square kerf).
The 24 tooth LU87R010 is ideal for your appication and is only $38 with free shipping from Amazon.
It’s worth the time to change the blade for even one cut.
-Paul
View Paul's profile
Paul
721 posts in 1468 days
#11 posted 07-11-2014 01:46 AM
I have the same saw, with the correct blades I haven’t found anything it can’t cut. I’ve never had my motor bog down once. Fewer teeth for thick stock like recommended above should do the trick.
Paul
Mark2457
#12 posted 07-11-2014 02:05 AM
Thanks guys
Mark2457
#13 posted 07-11-2014 02:08 AM
I use both
It s worth the time to change the blade for even one cut.
-Paul
- Ocelot
hey Paul
Have you used thin kerf on this saw? Steel city couldn’t tell me thickness of riving knife
View Paul's profile
Paul
#14 posted 07-11-2014 02:13 AM
I don’t remember the mm of the stock riving knife off the top of my head I can get it to you tomorrow. But it should be marked on the right side of the knife if your looking at the saw from the front.
Paul
Mark2457
#15 posted 07-11-2014 02:18 AM
I just measured the riving knife aand its 0.099
The Freud thin kerf has a .094 kerf, so it’s not going to work is it?
