Making chisel handles with no lathe
« back to Hand Tools forum
Forum topic by ColonelTravis posted 07-10-2014 01:08 AM 4051 views 0 times favorited 11 replies Add to Favorites Watch
View ColonelTravis's profile
ColonelTravis
1756 posts in 1860 days
07-10-2014 01:08 AM
Topic tags/keywords: chisel handle no lathe
No lathe now, and I see a latheless future. But I need a few chisel handles. First time I’ve tried this and the result for Test #1 wasn’t too bad – kinda boring design, plenty of flaws and room for improvement. Principle struggle was getting the tapering even all around, which almost happened but didn’t – any tips for that?
What I’m working with:
11 replies so far
View JAAune's profile
JAAune
1788 posts in 2283 days
#1 posted 07-10-2014 01:20 AM
I like the tapered octagon. Start with square stock then plane the corners but taper from the back, down to the ferrule. They look a little like Two Cherries but have a stronger taper.
View Pendragon1998's profile
Pendragon1998
74 posts in 1542 days
#2 posted 07-10-2014 04:36 AM
For a few pieces, perhaps this would work:
Building a Hand Drill Lathe (How To)
https://youtu.be/pTArvTJt5eI
Building a Horizontal Power Drill Mount
https://youtu.be/nhPtQwyXI_8
View waho6o9's profile (online now)
waho6o9
8165 posts in 2543 days
#3 posted 07-10-2014 04:42 AM
http://lumberjocks.com/BigRedKnothead/blog/39633
Mr. Rojo has a cool blog on making handles without
a lathe.
HTH
ColonelTravis
#4 posted 07-10-2014 06:07 AM
Totally ignorant of Red’s tutorial, thanks. Forgot to mention – no drill press. I do have a drill and could go the makeshift route, which is funny because all I’ve been doing lately is making things so I can make things that make things. What’s one more level!
Don’t anticipate much turning in my life, maybe it’s time for some 20% Harbor Freight action. But a drill press will be more versatile and probably a smarter buy.
But I thank everyone for the input.
View Tim's profile
Tim
3783 posts in 1927 days
#5 posted 07-10-2014 05:40 PM
Here's an article by Don McConnell about making traditional octagonal handles.
Here’s another with some discussion and some more links:
http://www.timberframe-tools.com/tools/replacement-chisel-handles/
It’s a no lathe, no drill press option.
ColonelTravis
#6 posted 07-10-2014 05:55 PM
Tim – excellent, thanks. The octagon part is easy, the tapering had me stumped.
waho6o9
#7 posted 07-10-2014 07:53 PM
ColonelTravis
#8 posted 07-10-2014 08:32 PM
I really enjoy the wkfinetools site. Lots of great information over there written by normal people like the guy who did that jig, which I had totally missed even though I had skimmed (key word) through his page of links:
Whathahellyawantapictureofmyfacefor? I got handles to make!
View Jerry Dye's profile
Jerry Dye
9 posts in 3027 days
#9 posted 07-11-2014 12:24 PM
I picked up a Harbor Freight 8 X 12 inch bench top lathe a few weeks ago for about $100.00 new from the store just for turning handles. This is a good lathe tho a bit under-powered. I had sold my big lathe some time ago because I used it too little and because it took up space I could use better.
-- jerryd
View bigblockyeti's profile
bigblockyeti
5094 posts in 1687 days
#10 posted 07-11-2014 01:08 PM
Is there any way you could chuck up the handle in a drill? Maybe with a bolt or screw in the end opposite where you’re trying to create the taper? If you could, you can use a disc or belt sander to form the taper.
View helluvawreck's profile
helluvawreck
30765 posts in 2833 days
#11 posted 07-11-2014 06:51 PM
It would not be difficult to build a small lathe that would be adequate to turn projects such as tool handles and furniture knobs, box feet and so forth. However, you can probably find a used small lathe on the market for under a hundred bucks that originally cost as much as 3 times that. A lot of people buy lathes and only use them a few times before they loose interest and then they just sit there and gather dust. If you want to do a little turning I would keep my eyes open and one will show up before you know it.
helluvawreck aka Charles
