Saw Blades
Forum topic by scvwood27 posted 07-09-2014 11:22 PM 1415 views 0 times favorited 21 replies Add to Favorites Watch
View scvwood27's profile
scvwood27
117 posts in 1945 days
07-09-2014 11:22 PM
Looking to purchase a new thin kerf rip blade for my 1.5 HP Delta Table Saw. After reading several reviews, I have narrowed it down between the Diablo and Marples both 24 tooth count. Any thoughts on which one would be a better purchase? Price is about the same, somewhere around $30. Has anybody tried both and have a favorite? I see a lot of Diablo blades being used in video posts and shop pictures, but hardly ever see any Marples. Thanks
21 replies so far
View jonah's profile
jonah
1695 posts in 3293 days
#1 posted 07-09-2014 11:32 PM
http://lumberjocks.com/knotscott/blog/36699
Knotscott rates both equally there. I’ve not used either. I use 40T combination blades for ripping.
View distrbd's profile
distrbd
2252 posts in 2440 days
#2 posted 07-09-2014 11:32 PM
With a 1.5 hp motor you could use full kerf blade ,a LM72RO10 would be my first choice
It has thicker carbide teeth that can last longer than TK blades.can easily cut through 2” hard maple.
-- Ken from Ontario, Canada
scvwood27
#3 posted 07-10-2014 12:13 AM
At what size motor should you stop using thin kerf?
View kdc68's profile
kdc68
2657 posts in 2271 days
#4 posted 07-10-2014 12:39 AM
I use the Diablo 24 tooth rip, 40 tooth combo, and the 60 tooth crosscut in my table saw. I like them because they are cheap and produce smooth cuts.
Before you invest in a tk blade, be sure the kerf will be wide enough for the riving knife or splitter on your table saw. If I remember correctly, the kerf on a Diablo is .098”
-- Measure "at least" twice and cut once
View knotscott's profile
knotscott
8006 posts in 3370 days
#5 posted 07-10-2014 01:16 AM
Both should prove to be very efficient at ripping, and neither is likely to leave an impressively smooth edge. Lumberjoe has tried both, and posted his findings here – http://lumberjocks.com/reviews/2934
I have tried the LM72 and the LU87, and can tell you that on a 2hp contractor saw and a 1.75hp hybrid, the LU87 was much easier to spin in thicker rip cuts.
View ColonelTravis's profile
ColonelTravis
1768 posts in 1888 days
#6 posted 07-10-2014 01:23 AM
I defer to knotscott on all blade knowledge but when I had my in my 1.5 HP saw, I can also say the Freud LU87 was the best blade I put in there.
scvwood27
#7 posted 07-10-2014 02:23 AM
How much more efficient is a 24 tooth blade then a 50 tooth combo blade at ripping stock? I have a 50 tooth already, do I need a 24 tooth also?
View txn's profile
txn
139 posts in 1453 days
#8 posted 07-10-2014 02:45 AM
All of my blades are diablo I absolutely love them from their price point and performance. I have a 10in 50 tooth for ripping a 90 tooth for cross cuts on the table saw and a 12in 80 tooth on the miter saw no complaints here
knotscott
#9 posted 07-10-2014 09:19 AM
- scvwood27
For thick ripping the 24T is the way to go. Huge difference when you get much over 1” thick of dense hardwood.
View rick1955's profile
rick1955
264 posts in 1425 days
#10 posted 07-10-2014 09:59 AM
- scvwood27
24 teeth requires much less power for ripping then a 50 tooth blade for ripping. A full kerf blade will give you a much nicer finish than a thin kerf blade. You do need a 24 tooth blade for ripping and more so especially if you have a 1-1/2 hp saw. Also a dedicated rip blade has flat ground teeth as opposed to the alternating bevels of teeth on a combination blade which makes it cut easier and cleaner. Dedicated ripping and cross cutting blades will give you the maximum finish where as a combination blade is a compromise in both types of cut.
-- Working smarter with less tools is a true crafts person...
Craftsman on the lake
2790 posts in 3432 days
#11 posted 07-10-2014 10:42 AM
I have the freud ice blade. 24t bu it is thick. And the teeth are massive in width and length. I also have a delta/rockwell contractors saw.. older. The blade has made all the difference. The reason a 24t blade cuts faster (and works better in lower powered saws) is that it can move the sawdust out of the teeth faster. The cut is less smooth but I find that it’s still fine for gluing. Sometimes I pass it through the jointer after but not often.,
knotscott
#12 posted 07-10-2014 12:13 PM
... A full kerf blade will give you a much nicer finish than a thin kerf blade.. ...
- rick1955
I don’t agree with that statement if you’re using high quality blades. In theory, if all else is equal, a full kerf blade should be less prone to deflection. Deflection with good TK blades was rarely an issue when I used them, and the finish was very comparable the vast majority of the time.
View bigblockyeti's profile
bigblockyeti
5111 posts in 1715 days
#13 posted 07-10-2014 01:03 PM
I’ve used a 40T thin kerf Diablo combination blade and a 24T thin kerf Diablo ripping blade on my 3hp cabinet saw and the main difference was the ability to run stock through the ripping blade at a much higher rate. The cut quality was only very slightly lower.
scvwood27
#14 posted 07-10-2014 02:52 PM
Looks like a need a 24 Diablo. Didn’t get much feedback on the Marples, I guess it isn’t very popular. Thanks guys and gals.
View paxorion's profile
paxorion
1107 posts in 2039 days
#15 posted 07-10-2014 03:59 PM
I use both a Freud Diablo and an Irwin Marples. Both are made in Italy and perform beautifully. I don’t think you will really notice a huge difference between the two. The Irwin has more carbide, so it may be a candidate for resharpening in the future.
What I’ll argue is the biggest difference between the two is availability. You can easily find the a range of the Freud Diablo at HD, whereas the Irwin is newer and more sparse if you want to see it in person before buying.
-- paxorion
