Just a heads up.....
« back to Hand Tools forum
Forum topic by Bill White posted 07-09-2014 07:58 PM 1390 views 0 times favorited 10 replies Add to Favorites Watch
View Bill White's profile
Bill White
4904 posts in 3927 days
07-09-2014 07:58 PM
I’ve not necessarily been a big fan of borg tooling, but recently needed to make some fine/clean cross grain cuts.
Bought an Irwin #213104 pull saw on a whim. Just used it today for its intended purpose.
Worked like a champ. Danged if I won’t use it more often on DTs and mortice/tenon joints.
I was impressed. Straight and clean cuts. No tear out on SYP.
I guess that I might need to rethink.
Has Irwin done a major re-do on quality/value?
Thought ya might like to know.
Bill
-- bill@magraphics.us
10 replies so far
View richardwootton's profile
richardwootton
1699 posts in 1921 days
#1 posted 07-09-2014 09:00 PM
I have the same saw and it does cut cleanly. The plate on mine broke teeth and bent pretty quickly, but what more can you expect for a saw under 20 dollars?
-- Richard, Hot Springs, Ar -- Galoot In Training
View dawsonbob's profile
dawsonbob
2821 posts in 1722 days
#2 posted 07-09-2014 09:07 PM
I have the same saw and it’s been going strong for about a year, which is about a year longer than I expected. It’s been a good value for the price.
-- Mistakes are what pave the road to perfection
View palaswood's profile
palaswood
941 posts in 1717 days
#3 posted 07-09-2014 10:20 PM
I dont know about the pull saw, but I did my research on a carpenter saw and time and again the reviews for the Irwin 24” came back off the charts. I got the 9tpi coarse for around $25 and love it!. I only use my sharksaw pull saw for smaller cuts, but otherwise its the Irwin every time. Often faster (And safer) than setting up a cut on a powered saw.
-- Joseph, Irvine CA, @palas_woodcraft on Instagram
View Buckethead's profile
Buckethead
3194 posts in 1835 days
#4 posted 07-09-2014 11:26 PM
I also bought one, some time ago. My intention was to use it for cutting dovetailed tenons into the legs of a workbench, which I did, but afterwards I was going to toss it into the work truck for miscellaneous abuse on the fly. I use it very often, and it cuts cleanly and quickly. I have another pull saw that might cut a touch better, but it has a back, so not as versatile. The Irwin has a rip and crosscut tooth set, and no stiff back. It will cut as deep as I’m willing to go.
I have since changed my mind about using it for garbage work. It stays in the shop.
-- Support woodworking hand models. Buy me a sawstop.
View crank49's profile
crank49
4030 posts in 2937 days
#5 posted 07-09-2014 11:33 PM
I have posted several recommendations for that saw over the last few years.
I also like the Jorgensen Pony Pull Saw, similar to the above mentioned Shark Saw.
The Jorgy is about twice as big and twice as coarse but the two saws really cover a lot of capacity.
palaswood
#6 posted 07-09-2014 11:39 PM
as for the sharksaw, it has fine and coarse teeth on either side of the blade (gotta be careful when reaching over to stabilize a cut off about to drop!), but in my experience the coarse teeth are junk
crank49
#7 posted 07-12-2014 10:57 PM
I thought the coarse teeth were junk also, until I realized they are filed RIP cut. They will not crosscut hardly at all, but do okay ripping.
Buckethead
#8 posted 07-12-2014 11:05 PM
They don’t provide a superior rip, but they do rip faster than the crosscut side. They don’t do so with the same excellent feel as the crosscut side.
View Crank50's profile
Crank50
173 posts in 1542 days
#9 posted 07-16-2014 01:21 PM
Just yesterday I happened to be in Home Depot and saw that they are clearance selling the Irwin pull saws also.
Irwin #213104 pull saw for $1.00.
I bought all five remaining saws.
For what it’s worth, since HD is closing out all Irwin products that also includes Vise Grips. I got two of the big grips with the swivel pads, similar to the Kreg clamp, for $8.00
I know they don’t always have the same sales at different stores so your mileage may vary.
View Ocelot's profile
Ocelot
1958 posts in 2604 days
#10 posted 07-16-2014 08:27 PM
This looks exactly like the Shark 10-2204 Dowel/Dovetail/Detail Saw which right now is $10 on Amazon with free shipping on orders over $35.
I have the Shark and have enjoyed using it, though I suspect mine is a little dull now.
-Paul
