working with LED's
« back to Coffee Lounge forum
Forum topic by Belg1960 posted 07-09-2014 10:57 AM 1155 views 2 times favorited 4 replies Add to Favorites Watch
View Belg1960's profile
Belg1960
1068 posts in 3066 days
07-09-2014 10:57 AM
Topic tags/keywords: question
Guys, I just finished building an elevated deck and would like to add some led lighting underneath any one have any experience with these? I’m not looking for the store bought units, I want to use small assemblies and use a weatherproof box to make my own. Thanks Pat
-- ***Pat*** Rookie woodworker looking for an education!!!
View Gene Howe's profile
Gene Howe
10479 posts in 3429 days
#1 posted 07-09-2014 12:44 PM
SPAM
Put the best things in here slimming garcinia things that burn calories nutritionally healthy and we ll see what it looks like when it’s done when a storm we can finish it two ways leave the vegetables in pieces or take the Burmese XR tense smooth it out giving you a lot of body so we re going to and we ll see workbooks It’sgonna at the tomatoes goes we don t expect to see tomato and just the flavor and the caller can ginger so it s going this summer remove or knowing what s cooking there is a sweet potato stealth next the green cabbage is cut I know is that the alternatives to that cool notice.
http://slimminggarciniafacts.com/
- AlfredKZuniga
Craftsman on the lake
2791 posts in 3438 days
#2 posted 07-09-2014 12:49 PM
you can do a really good job for around $25 and it will be good stuff that works. And it’s easy to do.
I’ve done lots of this stuff. On furniture and home lighting. I’ve also learned a few things. The ribbon lights found on amazon are very good. They make some that are weatherproof. The ribbon lights are covered by a plastic bubble that goes the entire length of the ribbon. The ribbons are usually 16 ft long and have plugs at each end that plug into one another. So you can add more than one ribbon. The ribbon can be cut at each 4” as a red/blue/green light with one circuit is a section. so if you needed 20 feet you can buy two 16 footers, plug them into each other then cut the second one at 4 ft. You can buy little adapters that attach to the cut off piece so that you can use it if you cut it.
I’ve got some lighting up when I did the interior renovations. The place is finished now. Here’s a picture when i installed them. I’ve had it up for two years now and it’s still going strong.
You can get a small power supply or purchase a larger one that can be used to connect more stuff to it. Everything is 12 volts. You’ll need a controller. You can get ones that are wired or wireless ones. If you go wireless, like I have, Get the RF controller, not the IR one. RF means it’s a radio frequency device and works anywhere within several feet but you don’t need to point it in any direction. The IR one is infrared, like your TV controller. You’ve got to point it at a specific spot where the receiver is to get it to work.
The controller lets you choose a large range of colors, and make them do a bunch of stuff like strobe, blink, fade in and out from one color to another, fast or slow, and of course brighten, dim, etc. Collectively my two strands of light provide good ambient lighting for our house while watching tv or relaxing. Keep in mind that ‘white’ color is made up of all rbg lights on at once so white is really ‘off white’. not pure white. It has sort of a bluish tint to it.
Here’s a picture of one of the ribbons and a link on Amazon to it.
Here’s a pict and link to the RF controller and receiver
And a link to a small power supply to power them all
The little transmitter plugs into the power supply, The lights plug into the transmitter (it’s about the size of a stick of gum). If you want to run wires from the transmitter to the ribbon lights simple bell wire will do. Anything really it’s low current 12 volts. No danger at all.
#3 posted 07-09-2014 01:39 PM
I’ve also installed these LED light in the house. You’d have to find outdoor ones or adapt them for out of doors though. Not expensive, extremely bright and the gimble turns in different directions.
They take something like 9 watts of electricity, dim nicely with the right dimmer and have a something like 10 yr light bulb expectancy in them. Dim them and they’d last a lot longer. They install easily and work well for us.
This one is home depot, about $32
View ChrisK's profile
ChrisK
1964 posts in 3082 days
#4 posted 07-09-2014 04:23 PM
I used Inspired LED for my cabinets, bought the power supply separate because it was cheaper and I wanted dimmable. Sometimes buying something versus building it makes financial sense.
I have purchased from both these sites. Amazon carries quite a bit also.
http://inspiredled.com/
http://www.parts-express.com/
-- Chris K
