Question on lathe tail stock quill
« back to Woodturning forum
Forum topic by shopmania posted 07-09-2014 03:31 AM 2508 views 0 times favorited 6 replies Add to Favorites Watch
View shopmania's profile
shopmania
701 posts in 3179 days
07-09-2014 03:31 AM
Topic tags/keywords: question lathe turning
I was using my lathe as a horizontal boring machine to make a 3/4” hole. I need it to be about 5” deep, so after I ran the bit in the entire travel of the quill, I added a bit extension. I can no longer get the quill to advance, the threaded center attached to the hand wheel just backs out of the tail stock body. I know I must have done something wrong when I took it apart to change from the live center to the drill chuck, but I don’t know what I did or how to fix it.
Any help or suggestions? Thanks!
-- Tim, Myrtle Beach, DrTim@ONeillChiro.com- Just one more tool, that's all I need! :)
View bigblockyeti's profile (online now)
bigblockyeti
5117 posts in 1718 days
#1 posted 07-09-2014 03:33 AM
There is either a screw that rides in a groove of the threaded shaft or an e-clip or similar. What is the make, model and age of your lathe?
View Woodknack's profile
Woodknack
11624 posts in 2377 days
#2 posted 07-09-2014 04:50 AM
As said above, there will be something that prevents the tailstock shaft from turning, just reengage it.
shopmania
#3 posted 07-09-2014 11:08 AM
It is a jet lathe, 12-32, that I bought used 3 years ago. It’s the newer white color, not blue like my older Jet bandsaw. There is a set screw that rides in a groove on the outside of the morse taper shaft, and I’ve got that engaged now. I didn’t for a while and I think that’s part of my problem. I got it all back together, and I can make it advance the quill with no pressure against the tail stock, but against resistance it just pushes the threaded shaft that the hand wheel connects to out the back of the tail stock
View Jim Jakosh's profile
Jim Jakosh
20482 posts in 3103 days
#4 posted 07-09-2014 12:21 PM
Hi Tim. I see that all the time on the lathes at school the kids are using. The lock screw on the tail stock serves two purposes. I lock the quill when you are using a center but the end of it rides in a groove and serves as a key to keep the quill from turning when turning the hand wheel for advancing. You can also turn some lathe too far and the handwheel screws the quill out too far off the thread. In that case you just pull the quill back to engage the thread and it will back out.
There is a set screw near the back that has to be in a groove in the handwheel shaft. That is what holds the handwheel in once you unscrew the quill all the way. Take that out and the handwheel should come out.
Do you have a picture?
bigblockyeti
#5 posted 07-09-2014 12:23 PM
I could only find a 12×36 lathe: http://content.jettools.com/assets/manuals/708352_man_EN.pdf
Index No. 48-1 on page 14 is defined as a “C-ring” that will keep the threaded shaft out of the tail spindle.
shopmania
#6 posted 07-09-2014 09:23 PM
Yes it is a 12-36 lathe. Looks like I lost the C-ring! Maybe I’ll find it in the saw dust, or have to get a new one. Thanks!
