Couple of small burrs on poly finish
Forum topic by Josh posted 07-08-2014 02:36 PM 1332 views 0 times favorited 10 replies Add to Favorites Watch
View Josh's profile
Josh
9 posts in 1656 days
07-08-2014 02:36 PM
Topic tags/keywords: question oak finishing
Hey all,
First post on here, I have lurked in the past but finally joined. I am currently building a shadowbox for my Fiance’s Dad’s flag and awards. He passed about 8 years ago and the family never received a flag, so after some effort I was able to get one and all of his awards, she doesn’t know about any of it. I plan on suprising her with this at the rehearsal dinner for our wedding on the 18th. On a couple of pieces of it I am having a hard time getting that perfect finish and have a couple of “burrs” on the finish. I have sanded between each coat of poly and am to what I would consider the final coat. The shadow box is made of all oak. Any help would be appreciated as this is a hugely important project to me and I want to do everything I can to make it perfect.
Thank you so much,
Josh
PS. I didn’t really like the layout of what I could purchase in a store and also thought that building it myself would be the best tribute I could give to the man who I wish I could have met
-- Do or do not, there is no try
10 replies so far
TheWoodenOyster
1317 posts in 2173 days
#1 posted 07-08-2014 02:55 PM
Great story!
Take some 0000 steel wool and rub the entire surface out. The burrs will probably go away. I have found that when finishing with poly in a regular shop environment (not a professional spray room that is totally dustless), it is nearly impossible to get a finish without dust nibs. You aren’t doing anything wrong, it is just part of the process. Do it on the backside or a part that isn’t visible first to make sure it won’t mess up the look that you are trying to acheive. Rubbing with steel wool will make a gloss finish look more like satin, just a heads up.
Good luck
-- The Wood Is Your Oyster
View Mike67's profile
Mike67
97 posts in 3574 days
#2 posted 07-08-2014 02:56 PM
Looks like a great flag case. Nice work. You have a couple options for getting rid of the nubs in the finish. Those are caused by dust that settles on the finish while its drying. They’re pretty hard to avoid but you can minimize them on future projects by keeping the shop as clean as possible. The easiest way to get rid of them is by rubbing the finish with some 0000 steel wool. Be aware that if you’re going for a gloss finish, this will soften the gloss a little. I like adding a coat of wax after the steel wool to get a really smooth feel to the project but it isn’t required. Another option you can try before running out for steel wool is to rub it with some brown paper. Take a brown paper shopping bag or lunch bag and crumble it up a few times, then try rubbing the finish with it. You can usually knock down dust nubs without changing the gloss of the finish this way. Weather you use wool or paper, make sure you give the finish a few days to cure first (you want it as hard as possible for this), and test in an inconspicuous spot to make sure you like the results before you dive in.
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2607 days
#3 posted 07-08-2014 03:40 PM
Also agree with the 0000 steel wool. I’ve had good luck just rubbing the steel wool on some Johnson’s paste wax, then rubbing out the finish with that. Keep rewaxing the steel wool as it runs out of wax. Once the wax sets, buff it out with a shop towel.
View gfadvm's profile
gfadvm
14940 posts in 2928 days
#4 posted 07-09-2014 12:33 AM
Give that whole project a light sanding with 320 grit and then wipe on a final coat of poly/mineral spirits.
View Josh's profile
Josh
#5 posted 07-09-2014 03:57 AM
Just wanted say thank you for the fast responses and quality responses. Since I am going after a semigloss finish I think I try the shopping bag idea first. My only other stupid question, is I do plan on waxing it, is turtle wax a huge no no or is it a acceptable practice to use car wax on furniture. I see lots of conflicting opinions elsewhere
THANKS
Josh
View Monte Pittman's profile
Monte Pittman
30143 posts in 2576 days
#6 posted 07-09-2014 10:27 AM
Great story. Of course making it yourself was the right choice. Shows thought and commitment. If you are using oil based poly, maybe use a wipe on to finish it.
Welcome to Lumberjocks
BinghamtonEd
#7 posted 07-09-2014 11:04 AM
I haven’t used turtle wax, but have used macguires wax before and it worked. A can if Johnson’s paste wax is $6 (Lowes has it in the cleaning section, so does my local grocery store) and will last a loooong time. It’s also good to apply to planer/table saw/jointer/ etc tables.
gfadvm
#8 posted 07-09-2014 06:55 PM
Turtle wax will leave a white residue if you miss any when buffing it off.
View Josh's profile
Josh
#9 posted 12-16-2016 08:19 PM
I know it’s been a long time, but I wanted to say thanks to those that helped me out with this and show you the finished product… Ps my wife started bawling when I gave her this! https://s3.amazonaws.com/vs-lumberjocks.com/oiaodyi.jpg!
View Woodchuck2010's profile
Woodchuck2010
724 posts in 1096 days
#10 posted 12-16-2016 09:01 PM
Well done sir!
-- Chuck, Michigan,
