Question for my power tool brethren.
Forum topic by Woodwrecker posted 07-07-2014 08:04 PM 1216 views 0 times favorited 15 replies Add to Favorites Watch
View Woodwrecker's profile
Woodwrecker
4121 posts in 3480 days
07-07-2014 08:04 PM
Question for my power tool buddies.
I know at least a couple of you have this same machine.
My 14” Sears Band Saw.
New blade.
Guides all set just right.
No obstructions.
Everything set JUST right.
When I turn it on, it seems a little slow starting up but does get up to speed.
BUT, when I begin to push a board through it to cut it, even a moderate amount of feed pressure will slow the blade down to a stop.
When I release the feed pressure, it will get going again.
This never happened before.
The machine is about 5 or 6 years old and has served well.
Question:
What do you think ? Brushes ?
It isn’t electrical feed, as other machines work fine on that cord.
And save the “get a new machine” comments. The boss says that’s not in the cards right now…
Thanks for your help.
Eric
Thanks a bunch
-- Eric, central Florida / Utor praemia operibus duris
15 replies so far
View bigblockyeti's profile
bigblockyeti
4983 posts in 1625 days
#1 posted 07-07-2014 08:12 PM
It doesn’t have brushes, so that’s not a possibility. Did you check the belt tension? Does it get up to speed slowly if the blade is off the saw? You could have a failing capacitor which can be checked with a digital multimeter with such capabilities or a motor shop could check it for you.
View UpstateNYdude's profile
UpstateNYdude
912 posts in 1887 days
#2 posted 07-07-2014 08:27 PM
+1 to what Yeti said my grandfathers had a bad cap which caused similar symptoms, good luck.
-- Nick, “I am always doing what I cannot do yet, in order to learn how to do it.” – Vincent Van Gogh
View Jim Jakosh's profile
Jim Jakosh
20071 posts in 3010 days
#3 posted 07-07-2014 08:42 PM
It’s fixable!!
When you put a board through it and the blade stops, is the motor still running at regular speed?
Boy, I have had nothing but problems with my sears lathe motors. Looking at your motor it does not have brushes. It probably has a starting capacitor to bump it to get it started and my lathe has a run capacitor also to keep it running. I don’t know if a weak run capacitor will make it run slow?? Check if you have 2 capacitors?? They can be removed and checked at a motor shop. A trick I learned when my Sears capacitors continued to blow out every 6 months was to get one with the same capacitance but double the voltage. I did that and the last one is in there 5 years now! I bought it at a motor shop for $8.80 instead of $26 at Sears I found the armature on my lathe was out of center on mine and had to turn it down because it was rubbing on the field windings and heating up.
But yours might not be in the motor!!
Check the belt for tightness first. Then check both pulleys to see if one is slipping on the shaft- like a key fell out or a loose set screw. Also look at it when you turn it on to see if it running full speed when the blade is running slow. If the motor runs full speed you can eliminate it and look and the belt system for the loss in speed.
Please let us know what you find??
............Cheers, Jim
16272 posts in 4123 days
#4 posted 07-07-2014 08:42 PM
I was thinking capacitor even before I read the other responses.
View nomercadies's profile
nomercadies
589 posts in 2243 days
#5 posted 07-07-2014 08:53 PM
I need to watch this.
-- Chance Four "Not Just a Second Chance"
View MrUnix's profile
MrUnix
6346 posts in 2103 days
#6 posted 07-07-2014 09:06 PM
Check that everything turns freely by hand, with and without the blade installed. Do the same with the drive belt on and off. With belt off, make sure motor turns freely. That should at least isolate your problem to either the saw or the motor. It does sound like the motor though.. If all the easy stuff above checks out, I’d open it up and test the capacitor and centrifugal switch.
View Bricofleur's profile
Bricofleur
1440 posts in 3097 days
#7 posted 07-07-2014 09:46 PM
I can’t be with any help here my friend. However, I wish you’ll find the problem soon, free your mind, be happy and sleep well.
Best wishes,
Serge
PS: While writing I came up with the idea of blowing the motor to get any sawdust out. But you probably have done it !!!
-- Learn from yesterday, work today and enjoy success tomorrow. -- http://atelierdubricoleur.wordpress.com
23552 posts in 3755 days
#8 posted 07-07-2014 10:21 PM
I had a problem like that with my bandsaw. It turned out to be the wrong blade
This may not be your problem as you have had your machine for a while but I did find the bigger teeth & a lower TPI made an enormous difference.
Woodwrecker
#9 posted 07-07-2014 11:22 PM
Thank you all very much.
I think I may have gotten some lubricant on the belt when I was applying it after setting the guides & everything.
I can’t hear a difference in the motor (as deaf as I am…lol) when the blade slows down. So I think the belt may have been slipping.
I cleaned it as best I could with some mineral spirits and will leave the cabinet door open tonight to let it air out.
Thank you all again.
I’ve never met most of you, but I sure count you as my friends.
Eric
View distrbd's profile
distrbd
2252 posts in 2351 days
#10 posted 07-08-2014 02:08 AM
is the motor wired for 110volts or 220v?
-- Ken from Ontario, Canada
#11 posted 07-08-2014 02:41 AM
Wrecker, please let us know if that fixed the problem
Woodwrecker
#12 posted 07-08-2014 02:52 AM
SOLVED !!!
I am one of those guys who goes nuts until a problem is fixed.
And, thanks to you all here, I had more things to check.
I went back out there and cleaned the hell out of the belt, re-tracked the belt in the grooved pulleys just right and tensioned it more.
And WHAMO, it works like new !!
THANK YOU AGAIN MY BROTHERS.
Tomorrow is going to see some re-sawing for some drawer fronts.
Thank you all very much again !!!
#13 posted 07-08-2014 04:40 AM
Good news Wrecker.
View Jim Bertelson's profile
Jim Bertelson
4150 posts in 3069 days
#14 posted 07-08-2014 04:57 PM
Glad to see you solved your problem, don’t think you need any more advice.
But, just for future reference:
I think you can get link belts for most things, and they run smoother with less fuss. I put one on my old Delta Contractor’s saw, and got some cast pulleys as well. Then rewired it for 220V, and use good blades. It runs very smooth. I still have to buy a decent band saw for here in Anchorage. I have a modest 14” Grizzly in La Conner, and it runs beautifully.
Got home from La Conner this weekend, vacation was too short, and I am already busy at work again. The weather has been good in Anchorage and La Conner, so no matter where I am it is nice.
Have a good one…............
-- Jim, Anchorage Alaska
View hoss12992's profile
hoss12992
3990 posts in 1797 days
#15 posted 07-08-2014 05:23 PM
If you did get some lubricate on the wheels/belt, and I know you said you cleaned them, but a trick that I used on a old bandsaw I recently picked up at a estate sale, was I sprayed some non slip on it, which you pick up at a auto part store, and its a cheap fix, especially if the tires on the wheels are starting to get a bit loose. I took off the tires, and sprayed it on the wheels, and then put the tires back on, and bam, problem fixed. Hope you get it going soon buddy
