contractor saw dust collection upgrade
Forum topic by pauldye posted 07-07-2014 05:39 PM 1268 views 1 time favorited 5 replies Add to Favorites Watch
View pauldye's profile
pauldye
67 posts in 1953 days
07-07-2014 05:39 PM
Topic tags/keywords: jig bandsaw tablesaw
I saw a half-page write-up in a dust collection book that showed a way to box off the bottom of a contractor saw. It looked easy and thought I would give it a try. With my PowerMatic saw, it was a little more difficult because the horizontal braces have a 45 degree angle, which forced me to cut multiple pieces for the sides, and to offset the sides to the angle’s width.
I used 3/4” plywood for the side bottoms, and 3/8” plywood for the bottom and back. Pegboard was used as pattern makers choice. I may need to replace the pegboard with hardboard, if suction is effected.
I used a bandsaw to cut the smaller shapes and notches, to get the right fit.
Thanks for looking.
5 replies so far
View Bill White's profile
Bill White
4815 posts in 3830 days
#1 posted 07-07-2014 06:01 PM
I guess that mine is over-simplified. I have a dust pan with a 4” duct on my Grizz G0444Z. Put a small baffle on the motor side that would not create a loss in air flow.
I have to take the baffle off for angle cuts, but they are not too common.
The DC above the blade is not great, but is easily cleaned.
I will hook up the DC and blow out any residuals that will be sucked into the pan/DC.
Make-up air is the critical issue for DC on contractor saws.
Bill
-- bill@magraphics.us
View English's profile
English
586 posts in 1346 days
#2 posted 07-07-2014 07:09 PM
Nice looking set up. Does it work?
-- John, Suffolk Virgina
View knotscott's profile
knotscott
7817 posts in 3245 days
#3 posted 07-07-2014 07:48 PM
That should do the trick! Nice job.
View jmartel's profile (online now)
jmartel
7615 posts in 2019 days
#4 posted 07-07-2014 09:19 PM
On my list of things to do to mine. Nice job
View spcbike's profile
spcbike
40 posts in 1843 days
#5 posted 07-09-2014 10:10 AM
Very well done!
