Narrowest board you'd rip on a table saw?
Forum topic by ColonelTravis posted 07-07-2014 03:52 AM 2533 views 0 times favorited 23 replies Add to Favorites Watch
View ColonelTravis's profile
ColonelTravis
1768 posts in 1889 days
07-07-2014 03:52 AM
Topic tags/keywords: rip table saw narrow
Would you rip a 1” wide stick?
2”?
I don’t mean ripping narrow strips off a wide board. How narrow is too narrow to begin with? When you can’t use a push stick any more? How narrow can your push stick be? Just wondering, not experimenting, I don’t know the point when your safety is blown and this is info. I obviously haven’t been able to find anywhere.
23 replies so far
View jmartel's profile
jmartel
7882 posts in 2145 days
#1 posted 07-07-2014 03:52 AM
I’ve ripped off of a 1” wide board before. Not ideal though.
View Woodknack's profile
Woodknack
11608 posts in 2375 days
#2 posted 07-07-2014 05:09 AM
1”, no problem. I don’t think twice about it until I get down to 1/2”.
View vskgaming's profile
vskgaming
83 posts in 1610 days
#3 posted 07-07-2014 05:26 AM
As long as i can clear the anti kick back pawls with the big orange Tool Designs push stick i am good, about 3/4”.
-- VSKGAMING
vskgaming
#4 posted 07-07-2014 05:26 AM
Sorry for the double post.
-- VSKGAMING
View Holbs's profile
Holbs
1864 posts in 2025 days
#5 posted 07-07-2014 05:38 AM
as thin as my Grrr-ipper can go :) 1/4” i believe!
-- The Carpenter Bee is derived from the Ancient Greek word wood-cutter
View DeLayne Peck's profile
DeLayne Peck
541 posts in 2197 days
#6 posted 07-07-2014 06:53 AM
Here is my shopmade Rip-Snorter Push Block Provides control and safety. Works beautifully.
There is a better way to go for really thin strips. Take a look at Rocklers Thin Rip Table Saw jig.
-- DJ Peck, Lincoln Nebraska. Lord, keep your arm around my shoulder and your hand over my mouth.
View NiteWalker's profile
NiteWalker
2737 posts in 2572 days
#7 posted 07-07-2014 08:39 AM
I’ve ripped down to 1/8” with no problems.
A riving knife and push stick (a sacrificial one in the case of 1/8” rips as my pushers are 3/4” thick) keep it safe.
View b2rtch's profile
b2rtch
4861 posts in 3044 days
#8 posted 07-07-2014 10:22 AM
1/4” very often
-- Bert
View Redoak49's profile
Redoak49
3240 posts in 1984 days
#9 posted 07-07-2014 10:50 AM
Yes, one can rip narrow pieces but you need to stop and think it through first. A very good jig or push stick is needed. Remember that the thin pieces trapped between the fence and the blade can come out like a high speed arrow.
View rick1955's profile
rick1955
264 posts in 1426 days
#10 posted 07-07-2014 11:57 AM
I’ve ripped strips 1/16” with no problem. I prefer to use a zero clearance insert and if just needing a quick one off strip instead of doing an elaborate jig set up I simply rip half the lenght and lifit it up, flip it over and rip the other half and lift the 1/16” piece up. No danger of kick back or any problem. I use this technique on saws that don’t have outfeed tables. It’s a saimple safe techique I’ve been using for 40 years and I can’t say I’ve read any others dong this in the magazines or forums. Also I’ve been in the trade professionally for 40 years.
-- Working smarter with less tools is a true crafts person...
View bigblockyeti's profile
bigblockyeti
5112 posts in 1716 days
#11 posted 07-07-2014 12:12 PM
As long as you have a push block of some kind that will stay behind the piece trapped between the blade and fence, while keeping your fingers a safe distance away from the blade, I see no reason for having a minimum width.
View Jim Finn's profile
Jim Finn
2656 posts in 2917 days
#12 posted 07-07-2014 12:17 PM
Cutting thin strips like this is why I make ten push sticks at a time. They get chewed up doing this. Makes it safe though. I keep the fence between me and the blade so that if there is kick back it does not hit me.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
View bondogaposis's profile
bondogaposis
4723 posts in 2346 days
#13 posted 07-07-2014 12:56 PM
1/4” for me, I have push sticks made from 1/4” stock.
-- Bondo Gaposis
View paxorion's profile
paxorion
1107 posts in 2041 days
#14 posted 07-07-2014 12:57 PM
I think I’ve gone down to:
  • 1.5” when I have the guard and pawls in place and a push stick
  • 3/4” with the riving knife and a push shoe
  • 3/8” using the Grr-Ripper
-- paxorion
View NoThanks's profile
NoThanks
798 posts in 1524 days
#15 posted 07-07-2014 01:32 PM
I ve ripped strips 1/16” with no problem. I prefer to use a zero clearance insert and if just needing a quick one off strip instead of doing an elaborate jig set up I simply rip half the lenght and lifit it up, flip it over and rip the other half and lift the 1/16” piece up. No danger of kick back or any problem. I use this technique on saws that don t have outfeed tables. It s a saimple safe techique I ve been using for 40 years and I can t say I ve read any others dong this in the magazines or forums. Also I ve been in the trade professionally for 40 years.
- rick1955
Ditto,
Do it all the time.
-- Because I'm gone, that's why!
