Preserving rotten parts in wood for furniture
Forum topic by woodoogolem posted 07-06-2014 08:36 PM 1210 views 0 times favorited 7 replies Add to Favorites Watch
View woodoogolem's profile
woodoogolem
56 posts in 1453 days
07-06-2014 08:36 PM
Topic tags/keywords: question rustic refurbishing
I bought some low grade hard wood (damson or plum) which apart from some cracks also has larger nests and stripes of rotten wood. In fruit trees this is often the case and results in areas similar to a sponge.
I don’t want to throw half of the wood away, I also wouldn’t care the rooten parts if they wouldn’t crumble off so easily. This white stuff rather gives the wood some character :-)
I tried my luck by soaking the areas with transparent PU resin. Now I have to wait for the resin to harden thoroughly.
What other methods have people sucessfully tried or what else could be worth trying?
7 replies so far
View Monte Pittman's profile
Monte Pittman
29394 posts in 2363 days
#1 posted 07-06-2014 08:39 PM
Small areas with CA glue. Otherwise, tung oil will help.
runswithscissors
2766 posts in 2050 days
#2 posted 07-06-2014 11:59 PM
Git Rot is specifically for that kind of problem. JB Weld makes a similar kit. They are a thin, slow cure epoxy that soaks into spongy wood and hardens it. Works pretty well as long as you won’t be subjecting the item to physical stresses
View JoeWhite's profile
JoeWhite
24 posts in 1959 days
#3 posted 07-08-2014 06:32 PM
I’m looking to do something similar in some pine decking supports that I came across. I’ve planed them down and cleaned up the surfaces but there are still a lot of cracks. I want to turn the cracks in to a feature, maybe with some acrylic shavings or something to give it some color. Kind of like a veining look. Can I just mix some add some colored dust or chalk to the epoxy and fill in the cracks? And if so, how hard will it be to smooth out the epoxy with the wood?
woodoogolem
#4 posted 07-08-2014 06:39 PM
Git Rot looks like what I would need :-) unfortunately it is not easily available here in Germany. Similar to JB Weld which is on ebay but ships from the States include a hefty shipping. So I will look how my resin works and post my results later.
woodoogolem
#5 posted 07-08-2014 06:51 PM
For CA the areas are too large, but Tung is something I wanted to try anyway. Years ago I used hard oil for finishing but I think this would not be appropriate.
BTW: rotted or rotten?
woodoogolem
#6 posted 07-08-2014 06:58 PM
I have exactly done this. I sanded a scrap piece of this wood and filled empty areas. Then I let drops of resin soak in.
As mentioned in another post I am still waiting for the resin to harden. Then I want to try and sand or plane it. I will post about my results.
View CRJ's profile
CRJ
1 post in 1444 days
#7 posted 07-08-2014 09:22 PM
for filling holes or cracks one can “color” 5 minute epoxy with saw dust. For black one can use ebony – it doesn’t take much to color the epoxy.
