bubbles in polyacrylic
Forum topic by Sawdust2012 posted 07-05-2014 11:43 AM 1141 views 0 times favorited 5 replies Add to Favorites Watch
View Sawdust2012's profile
Sawdust2012
123 posts in 1707 days
07-05-2014 11:43 AM
I am applying multiple coats of polyacrylic to a maple bowl, not because I want to, but because I have to keep sanding out little bubbles that form when I brush it on. I am using a reasonably good brush, and, as the label suggests, trying not to over brush it. i am pretty sure this is a technique problem, but I dont know what I am doing incorrectly. Any help?
5 replies so far
View InstantSiv's profile
InstantSiv
262 posts in 1590 days
#1 posted 07-05-2014 11:56 AM
Did you stir it vigorously or gently? Stirring vigorously or shaking the can will cause bubbles. If that’s not the issue try a foam brush.
Sawdust2012
#2 posted 07-05-2014 12:00 PM
Thanks. I don’t shake it, but I may be stirring it a little aggressively. I’ll back off a little on the next coat and see what happens. My experience with foam is that it makes the problem worse. It may, however,, all go back to stirring.
View Bill White's profile
Bill White
4929 posts in 3955 days
#3 posted 07-05-2014 01:53 PM
Why not wipe on the poly?
Bill
-- bill@magraphics.us
View waho6o9's profile (online now)
waho6o9
8188 posts in 2572 days
#4 posted 07-05-2014 02:01 PM
Take an old clean T-shirt and wipe on the poly
as Bill suggested and that’ll solve the problem.
Thin coats seem to work better than trying too
thick a coat.
View Redoak49's profile
Redoak49
3240 posts in 1983 days
#5 posted 07-05-2014 05:30 PM
I struggle with the Polyacrylic as I have tried it a number of times. I do much better with straight poly.
