Troubleshooting thin and stringy hand plane shavings
« back to Hand Tools forum
Forum topic by bertwagner posted 07-04-2014 04:07 PM 1866 views 0 times favorited 21 replies Add to Favorites Watch
View bertwagner's profile
bertwagner
2 posts in 1298 days
07-04-2014 04:07 PM
Topic tags/keywords: plane diagnosis shavings troubleshooting
Hi all,
I just recently built my first hand plane and am very pleased with how it came out:
However, a good looking plane is useless if it doesn’t produce nice shavings. This is the kind of stuff I’m getting:
These shavings are coming from pine, but I experienced the same type of shavings from oak as well. When I make a pass with the plane, the shavings come off the board unevenly in little stringy parts (the boards I’m using are flat, so it shouldn’t be due to an uneven surface).
Things I’ve tried troubleshooting so far include:
1) Making sure the sole of the plane is dead flat in all directions
2) Sharpening the blade many times
3) Blade adjustments; depth, centering, etc…
I do know my mouth opening is larger than I intended to make – would a large opening cause these types of shavings? Or am I overlooking something else? I’m looking to get wide (as wide as the 2” blade) and thin shavings. Any advice on what to try next would be greatly appreciated, thanks!
21 replies so far
View ShaneA's profile
ShaneA
6879 posts in 2472 days
#1 posted 07-04-2014 04:45 PM
A pic of the mouth opening would help. But my first guess will always be the sharpness of the blade. Took me a while to know sharp, but once you do, you will realize what sharp is and isn’t.
The plane sure looks nice, well done.
View Loren's profile
9769 posts in 3521 days
#2 posted 07-04-2014 04:53 PM
You may be fooling yourself about the sharpness. You
may need a bit more blade protrusion.
A blade can feel sharp and cut hair on your arm but
it’s easy, especially freehand, to not actually get your
final polish to the edge of the bevel.
Positioning a friction-fit iron at ideal depth and even
all the way across the mouth of a wood plane can
be tricky.
You did flatten the sole with the iron and wedge
installed, right?
View cutmantom's profile
cutmantom
401 posts in 2908 days
#3 posted 07-04-2014 05:13 PM
blade sharpness ,possibly the blade is in bevel up?
View TiggerWood's profile
TiggerWood
271 posts in 1480 days
#4 posted 07-04-2014 05:16 PM
I need more pics. How precisely flat is the iron? How truly flat is the mortice? How well does the wedge mesh with the iron? I would believe your problem would most likely be with one of these three things.
View waho6o9's profile
waho6o9
8070 posts in 2450 days
#5 posted 07-04-2014 05:16 PM
Strop the blade.
Nice plane BTW.
#6 posted 07-04-2014 05:19 PM
Oh, yeah. Off chance if the chipbreaker is set almost right on the
edge of the iron a plane will tend to scrape. I would set the
chipbreaker back to about 1/16” while you’re figuring this out.
TiggerWood
#7 posted 07-04-2014 05:25 PM
Excellent point by Loren!
View Tim's profile
Tim
3707 posts in 1835 days
#8 posted 07-04-2014 05:26 PM
What’s the plane’s bed angle? Are you getting good contact with the wedge against the front of the plane iron? Any chattering? I’m guessing it’s a sharpness issue too, but I’ve used plane irons well past where I should have sharpened them and not had that type of shavings so the bevel up point is a good one too.
View Tim's profile
Tim
#9 posted 07-04-2014 05:27 PM
I don’t think I see a chip breaker there. It just looks like a thick blade and a wedge.
View shampeon's profile
shampeon
1775 posts in 2057 days
#10 posted 07-04-2014 05:38 PM
Just to add to the already good advise here, a large mouth opening will tend to allow much larger chips through, so we can cross that off.
Those are the kind of shavings you get from a scraper plane, which means the effective cutting angle is very high. It looks like your Hock blade is facing the right direction in the picture, if you have a bevel-down blade. Did you by any chance add a back bevel to the blade?
View bigblockyeti's profile
bigblockyeti
4888 posts in 1594 days
#11 posted 07-04-2014 07:06 PM
If my block plane is set up perfect, when it starts making shavings like that I know it needs to be sharpened.
View Pezking7p's profile
Pezking7p
3217 posts in 1525 days
#12 posted 07-04-2014 09:16 PM
Looks dull.
-- -Dan
View DocBailey's profile
DocBailey
584 posts in 2233 days
#13 posted 07-04-2014 09:40 PM
I’m with Shampeon on this one—
My very first thought upon seeing the second photo is that those look like the kind of shavings you get from a scraper or high-angle smoother.
Great for difficult grain, but not what you’re after.
View JohnChung's profile
JohnChung
398 posts in 1948 days
#14 posted 07-05-2014 05:53 AM
What is the effective angle of the iron?
bertwagner
#15 posted 07-07-2014 12:01 PM
Thanks everyone for your input! A couple of additional answers:
-Yes the sole was flattened with iron and wedge installed
-Chip breaker has been tried in multiple positions, but in the pictures above it was about 1/16” from the blade
-Bed angle is 60 degrees. With the wedge in between the blade and pin, there is no movement of the blade and no chatter
-Plane blade bevel is 30 degrees
It will be a few weeks before I can get back to troubleshoot the plane again, but I will check on everyone’s suggestions. It seems like the consensus is blade sharpness though. I’ve been using the Veritas Mk. II Honing guide to sharpen to 30 degrees. I noticed that the blade was a little off from 30 degrees (maybe 30.5 or 31?) so I’ve been slowly grinding it down on sand paper + flat surface in order to get the blade bevel to the correct angle for the honing guide. I’m guessing I still haven’t gone far enough and and will continue sharpening!
Thanks everyone for your input! Glad you like the plane.
