Are the cheaper Starrett squares worth buying?
« back to Hand Tools forum
Forum topic by Rob posted 07-02-2014 09:08 PM 2598 views 0 times favorited 23 replies Add to Favorites Watch
View Rob's profile
Rob
704 posts in 2945 days
07-02-2014 09:08 PM
Topic tags/keywords: square starrett
I don’t have a try square yet, and my current combo square is a piece of junk Swanson whose ruler/bar isn’t even flat along its face. I’ve managed to get by so far and I understand that wood moves so at some level precision goes out the window anyway; but I’ve heard/read enough testimonials about the difference in a $100+ Starrett square vs. a run-of-the-mill square, that I thought I’d look into upgrading. I was surprised to find several Starrett squares on Amazon that weren’t as obscenely-priced as what I expected.
For instance, they have a $14 try square. But they also have a $129 try square.
I’ve been thinking about buying the $14 try square and maybe one of their less expensive 4” or 12” combo squares in the $60-$80 range, but the fact that I can get a Starrett try square for 14 bucks has me wondering whether their cheaper stuff is really any better than anyone else’s products in the same price range, and whether I can really expect the sub-$100 Starrett combo squares to be any better than a $10 Empire square.
I can see that Starrett’s higher-priced squares have finer graduations on the ruler (1/64” vs. 1/32”). Is that it, or are their higher-priced squares also manufactured to tighter tolerances than their cheaper squares?
-- Ask an expert or be the expert - http://woodworking.stackexchange.com
23 replies so far
9770 posts in 3522 days
#1 posted 07-02-2014 09:34 PM
For woodworking the fine tolerance machinist tools
are overkill. They may be a pleasure to own. Get
some inexpensive things and keep your eye out
for machinist tools at yard sales, flee markets. You
will find them, cheap, and they are nice to have.
Lee Valley sells some really useful layout tools. I
particularly like the 4” double square and the
cabinetmaker’s sliding square. I also use a saddle square
that marks a line around a corner. All these are
most useful for laying out joints and hole positions.
4” double squares are available on ebay for something
like $20 too.
View bondogaposis's profile
bondogaposis
4529 posts in 2226 days
#2 posted 07-02-2014 10:54 PM
I think the cheaper square would be fine. It is very easy to check a square for “squareness”. They are easy to make too. Another way to get Starrett squares a little cheaper is on ebay. I’ve gotten all of mine that way.
-- Bondo Gaposis
View Planeman40's profile
Planeman40
1079 posts in 2635 days
#3 posted 07-03-2014 02:55 PM
Square is square is square . . .
Before I would spend $100 on a square for woodworking I would buy a cheap one and check it for squareness. Simply put it on a wood edge and mark a fine vertical line. Then flop the square and see if the line properly matches up to the flopped square.
I have two cheap Harbor Freight squares that are perfect and one older top end Stanley that is out of square. You just have to check.
View bonesbr549's profile
bonesbr549
1469 posts in 2942 days
#4 posted 07-03-2014 03:04 PM
I have many squares. I like my woodpecker ones just because the machined lettering is easy to see and I just lover their tools. I also have a groz 30$ set that had 3 in them that are fine. Love starret tools. the main thing is check one against another and if it’s good stick to that one and you will be ok. I do that with my tape measures as well. Got a boat load of em, but if you mix and match you can get into trouble. Like other said working with wood that moves is diff than metal.
View waho6o9's profile
waho6o9
8070 posts in 2451 days
#5 posted 07-03-2014 03:04 PM
http://store.harryepstein.com/cp/Squares/7121-006.html
Here’s a value that should be considered as well.
or
View ras61's profile
ras61
92 posts in 1396 days
#6 posted 07-03-2014 03:24 PM
Second the squares from Harry Epstein. They are PEC cosmetic blems that are 100% functional. I bought two.
-- "South Carolina is too small for a republic and too large for an insane asylum" - James L. Petigru, 1860
View MrRon's profile
MrRon
4566 posts in 3118 days
#7 posted 07-05-2014 07:19 PM
This is a relatively new tool in the Starrett arsenal. Note that it is called a “carpenters” try square. It is not a machinist’s square. It may be as close to accurate as their more expensive squares; it is probably made offshore. Note: the blade is marked only in eights of an inch.
View jtm's profile
jtm
223 posts in 1511 days
#8 posted 07-05-2014 08:07 PM
I bought the set of 4 machinist squares (Grizzly) on Amazon for ~$20.
They are all square as can be, and they make setting up my tools easier.
View longgone's profile
longgone
5688 posts in 3183 days
#9 posted 07-09-2014 03:47 AM
I have the Starrett square that is $14 and it is dead on accurate. It is made in china. I also own two other Starrett squares in the higher priced range and they are USA made and noticeable better quality…but accurate is accurate
View Andre's profile
Andre
1576 posts in 1680 days
#10 posted 07-09-2014 05:04 AM
I think what many of you are missing is will they still be square next year or 10 years from now? after building my Wabi sabi and borrowing a Starrett square I went to LV and bought some quality squares, the 12” Starrett included. I have an empire which I use all the time unless it is critical ! IMHO!
View Julian's profile
Julian
1254 posts in 2565 days
#11 posted 07-09-2014 02:47 PM
I have a Woodcraft 12” sliding square that was about $50. It was about a 1/2 degree off but truing up a square is fairly easy with the right size file. I also frequently use a 6” machinist square. These can be reasonably priced and found at many stores. I like having a precise square that I know is exactly 90 degrees. I personally would not use a cheap square, often made with plastic parts. But to each his own.
-- Julian
View Richard H's profile
Richard H
489 posts in 1555 days
#12 posted 07-09-2014 03:00 PM
Veritas has a house branded Precision Double Square for $40 that is made in the USA and excellent quality. I have one and it’s my go to reference tool for square for all my tools.
http://www.leevalley.com/en/Wood/page.aspx?p=44279&cat=1,42936
View ChefHDAN's profile
ChefHDAN
1007 posts in 2724 days
#13 posted 07-09-2014 03:26 PM
I have my grandfather’s Starrett squares, he was a mechanical engineer for Sperry during WWII, they needed some buffing with a bit of jewelers rouge to make them a bit easier to read, but they’re dead nuts accurate after all these years, even with the rare drop in the shop that always nearly stops my heart whenever it happens…
I’ve got several of the Incra tools as well, (from a great CL deal) but I never seem to be able to find the damn pencil to use with them .
MrRon
#14 posted 07-09-2014 06:38 PM
Starrett is a name that people have looked up to for a long time. They are not going to risk their reputation on a bad product.
View bit101's profile
bit101
106 posts in 1751 days
#15 posted 07-09-2014 09:25 PM
Another +1 for Harry Epstein. The PEC tools are way better than home store ones, an at Epstein, totally affordable.
