| Forum topic by DannyBoy | posted 307 days ago | 243 views | 0 times favorited | 6 replies | ![]() |
307 days ago |
Here is one to consider… I’m in the early planning stages of building a new base for my contractor saw. I’ve been looking around a lot and found several designs I like. Mostly, I’m looking for inspiration. My wants are a dust drawer below for shavings, a router table attached that can use the same fence, and completely mobile for my little shop. I also would like to figure a way of putting the shop vac I use for dust collection under the router wing. There will/can be plenty of cabinet space for this, so it seems plausible. However, I have read that the vac hoses can build up a large amount of static electricity and I have even felt it from time to time. So: Would I run too much of a fire risk combining the dust bin and a shop vac in the same cabinet? And: If I choose to do it this way, should I consider some sort of grounding (can that be done through a power chord)? ~DB -- He said wood...http://hickbyassociation.blogspot.com/ |
