table saw sled
Forum topic by scribble posted 07-02-2014 02:48 PM 1650 views 1 time favorited 19 replies Add to Favorites Watch
View scribble's profile
scribble
196 posts in 2321 days
07-02-2014 02:48 PM
Topic tags/keywords: jig tablesaw joining
Does anyone have any suggestions on good material for the fence on a cross cut sled?
-- If you can't read it Scribble wrote it!! “Experience is merely the name men gave to their mistakes.”
19 replies so far
View Pezking7p's profile
Pezking7p
3217 posts in 1772 days
#1 posted 07-02-2014 02:59 PM
Laminate two layers of 3/4” plywood together. I used a single layer of 3/4” and wish I had more. I would recommend against any solid wood, as it will have a tendency to change shape slightly with humidity. Save the pretty stuff for your furniture.
-- -Dan
View Bob Kassmeyer's profile
Bob Kassmeyer
227 posts in 3045 days
#2 posted 07-02-2014 03:02 PM
I have seen them made of laminated plywood, hardwood and even jointed tubafours. I guess it would depend on what your plans are for the sled. When I was working out of the garage everything seemed to warp so I made everything out of the cheapest materials I could find. I have not yet made one for my new to me table saw in an actual dedicated shop. My last one was made of a piece of OSB and a 2×4 fence and it worked for several years.
-- Bob Kassmeyer, Nebraska
View waho6o9's profile (online now)
waho6o9
8362 posts in 2697 days
#3 posted 07-02-2014 03:07 PM
3/4” Baltic Birch worked well for me.
View NiteWalker's profile
NiteWalker
2737 posts in 2697 days
#4 posted 07-02-2014 03:16 PM
Mine is currently an L shaped fence made from two pieces of 3/4” plywood screwed together. The horizontal piece keeps the vertical piece flat and straight, and is used for mounting to the base. In the base I tapped 1/4-20 threads and used thin ca glue to harden the threads. I drilled oversize holes in the horizontal piece so I’d have a bit of wiggle room for aligning the fence square to the blade.
My current sled was made from scraps because I wanted to try out the new fence design. I like this design a lot, and will be making a nicer sled later on with the same fence design.
I’ve tried the two pieces of plywood glued together, and it works fine too. I just like the L design for ease of adjustment and because it stays straight.
View skatefriday's profile
skatefriday
420 posts in 1603 days
#5 posted 07-02-2014 03:29 PM
I glued two pieces of 3/4” A1 prefinished veneer core plywood together (just what I had on hand) and it is slightly concave. So plywood won’t save you from warping. I really like the backing piece in an L configuration idea. I’ll be rebuilding my current fence with that idea.
scribble
#6 posted 07-02-2014 03:42 PM
SO i did use 3/4 Baltic birch and laminated 2 pieces together and it is not joiner flat. I think since I am in a garage that does have moisture issues I will do the 2/4 jointed due to not wanting to waste the good stuff.
skatefriday
#7 posted 07-02-2014 04:26 PM
I’m in a garage, but I’m also in a dry area of Southern California. Stuff
still warps. One of my biggest problems. What exactly do you mean by
2/4 jointed?
View Woodbum's profile
Woodbum
825 posts in 3186 days
#8 posted 07-02-2014 04:57 PM
I laminated 3 pieces of 1/2” Baltic birch. Structurally stable and flat. Works well on my Wm. Ng inspired sled.
-- "Now I'm just another old guy wearing funny clothes"
scribble
#9 posted 07-02-2014 05:19 PM
use a 2×4 pine board and make it flat with my joiner and planer.
View gfadvm's profile
gfadvm
14940 posts in 2810 days
#10 posted 07-03-2014 01:00 AM
Scribble, A 2×4 may have a really high moisture content. I used an OLD quarter sawn Douglas Fir 2×6 for mine, jointed square. It has been very stable.
skatefriday
#11 posted 07-03-2014 04:24 AM
I was the local HD a couple weeks ago looking to pick up a couple 2×4s for a project and everything was so wet I needed a towel to dry my hands after sorting through the stack. I ended up getting a 2×6 piece of redwood and milled it down to what I wanted as it was the driest stuff I could find.
TheWoodenOyster
1317 posts in 2055 days
#12 posted 07-03-2014 05:38 AM
Don’t want to steal the thread or anything, but all this warping talk makes me wonder why we don’t make such a crucial part on a crucial jig out of plastic. Anyone tried this?
-- The Wood Is Your Oyster
View GregD's profile
GregD
788 posts in 3256 days
#13 posted 07-03-2014 12:46 PM
Don t want to steal the thread or anything, but all this warping talk makes me wonder why we don t make such a crucial part on a crucial jig out of plastic. Anyone tried this?
- TheWoodenOyster
FWIW I scored a couple of the aluminum extrusions that Rockler uses on its router table fences and am using one as the fence on one of my sleds. The fence is straight and isn’t affected by humidity, but I did need to shim it a bit with tape to get the face perpendicular to the table. Every option seems to have its pros and cons.
-- Greg D.
View ChefHDAN's profile
ChefHDAN
1123 posts in 2970 days
#14 posted 07-03-2014 12:58 PM
I’ve collected a lot of Corian scrap from numerous café renovations and redo’s. I use quite a bit of it for fences sled runners etc. mills like wood with carbide and is rather easy to work with but smells awful when you’re cutting it.
skatefriday
#15 posted 07-03-2014 03:41 PM
I do a lot of work with laser cut acrylics for a robotics team and I’d be concerned about plastic breaking at a very inopportune time.
