Trash can recommendation for dust collection?
Forum topic by ADHDan posted 07-01-2014 06:25 PM 4050 views 2 times favorited 28 replies Add to Favorites Watch
View ADHDan's profile
800 posts in 2039 days
07-01-2014 06:25 PM
Topic tags/keywords: question
I’m looking to make my two-stage dust collection a little more compact and mobile. Here’s my current setup, using a 55 gallon fiber drum with a Rockler separator kit:
I’d like to switch out the drum for a smaller receptacle that’s easier to empty – something like a 30-40 gallon rugged trash can with a decent sealing lid and wheels. For now, I’ll use the same Rockler separator, but eventually I’d like to implement a Thien baffle. Anyone have recommendations?
I know it seems silly to ask for trash can advice, but considering that woodworking dust collection is a little different from normal trash can usage I figured I might as well ask.
-- Dan in Minneapolis, woodworking since 11/11.
28 replies so far
View DrDirt's profile
4421 posts in 3673 days
#1 posted 07-01-2014 06:39 PM
Don’t know what the “best” out there is… I’m sure a consensus will develop.
Most folks I see either use the fiber drums, or get a galvanized steel trash can.
e.g. this one at Lowes is 31 gallons. cost is 25 dollars at Lowes.
#2 posted 07-01-2014 06:42 PM
I wouldn’t mind using a smaller fiber drum, I could pretty easily attach some casters. Those things are just kind of a pain to track down, compared to trash cans.
View bondogaposis's profile
4632 posts in 2282 days
#3 posted 07-01-2014 06:54 PM
Behrens trash cans are very sturdy and commonly available.
-- Bondo Gaposis
View ducky911's profile
237 posts in 2720 days
#4 posted 07-01-2014 07:42 PM
Two stage DC are nice as you do not have to clean the filter so much. Cleaning the filter is a messy job. But I think that if you have a 2hp or less DC that you are better off not changing to a two stage as you will get a reduction in suction of 40+ percent.
I see a lot of people turning DC’s that are giving enough suction into easier to use DC’s that do not have enough suction.
I am currently doing this upgrade but I am also upping the HP blower.
View kdc68's profile
2643 posts in 2207 days
#5 posted 07-01-2014 10:01 PM
Another vote for Behrens trash cans
Here’s my mobile HF 2hp collector with a Behrens trash can separator with Thien Baffle. Project link provided if you are interested and/or want ideas to use
Click for details
-- Measure "at least" twice and cut once
View WhyMe's profile
995 posts in 1492 days
#6 posted 07-01-2014 10:52 PM
I used a feed container from Agri Supply.
View Kelly's profile
1939 posts in 2875 days
#7 posted 07-01-2014 11:19 PM
I went to the local fertilizer outlet, groveled and got a thirty gallon, plastic barrel you could park a truck on. It’s a little more narrow than a trash can and can be cut down and still be very strong (I’d cut it down to one of the strength rings).
As you can see in the picture, I added a window to track the level of dust in it.
View JoeinGa's profile
7733 posts in 1938 days
#8 posted 07-01-2014 11:40 PM
How bout one of these
They’re VERY heavy duty, and You can even get a wheel dolly for it.
View johnstoneb's profile
2816 posts in 2103 days
#9 posted 07-02-2014 12:14 AM
I tried a plastic trash can and had to go to a metal one. The plastic one collapsed under suction.
-- Bruce, Boise, ID
#10 posted 07-02-2014 01:15 AM
I used a Rubbermade (sp?) like the one above and it was far and above what other plastic ones were. I dropped a Western Tool top on it and it never hinted at collapse.
To be clear, you cannot compare the one in my post to a standard trash can. They have to hold up to shipping chemicals cross country. Of course, cutting the top off changes the strength, but even doing that, they are pretty tough. I haven’t developed a leak, even since I changed this over to my other, three horse collector, and cyclones are pretty fussy about leaks.
2693 posts in 1956 days
#11 posted 07-02-2014 07:41 AM
A 55 gal. steel drum should work very well. (I use a steel garbage can).
View The Box Whisperer's profile
The Box Whisperer
678 posts in 2001 days
#12 posted 07-02-2014 09:41 AM
I use a 65 gallon plastic drum used for making beer.
-- "despite you best efforts and your confidence that your smarter and faster than a saw blade at 10k rpm…. your not …." - Charles Neil
#13 posted 07-02-2014 01:58 PM
Note the blue beast in my photo with the cyclone is a thirty gallon. Takes up a bit less space and is, of course, easier to empty. The same would apply to the steel drums available from fuel supplies.
5811 posts in 2223 days
#14 posted 07-02-2014 02:04 PM
This works great for me—had to empty it three times last Saturday:
View TheDane's profile
5384 posts in 3594 days
#15 posted 07-02-2014 02:07 PM
Here’s my rig …
showing 1 through 15 of 28 replies
