Help Choosing Finish for Kids Chairs
Forum topic by Keith Kelly posted 07-01-2014 01:32 PM 875 views 0 times favorited 5 replies Add to Favorites Watch
View Keith Kelly's profile
Keith Kelly
263 posts in 1657 days
07-01-2014 01:32 PM
I’m building a small table + chairs set for my kids. We have a 2 year old as well as another due July 14.
Table: complete. It’s hickory/pecan. I used TransFast orange dye, followed up with a handful of layers of tinted shellac and GF Java Gel, then topped with a wipe-on poly mix (poly + MS). It took a lot of layers, and a lot of work. However, I achieved the med/dark finish with warm glow I was looking for.
Chairs (oak) – they are going to be scooted, bumped against the table, forks fallen on them, toppled over on the floor, banged against each other, and kids pocket buttons scraping against them as they sit and squirm.
I’m curious what type of varnish you’d use.
My coloring coats will likely be: TransFast orange, 1lb shellac, and GF Java Gel. I may modify that slightly if the chairs need to be darkened more, but those are the basics.
My considerations for the top coats are:
  • Wipe on poly mix
  • Spray Polyurethane
  • Spray Lacquer
  • Some custom varnish mix (solvent + oil + poly)
  • I’m open to other options.
What would you use?
For the record, this pic doesn’t do the finish justice. There is a good deal of depth, where the light catches the orange wood fibers differently depending on where you are standing in relation to the light sources. So, just imagine.
No pieces of the chair were glued at this point: :)
-- Keith - Bolivar, Missouri, http://www.SquareOneWoodworks.com
5 replies so far
View Monte Pittman's profile
Monte Pittman
29216 posts in 2332 days
#1 posted 07-01-2014 01:34 PM
If you think that there is a chance that they will chew on them, then I would use shellac. It’s what I use on baby cribs for that reason.
Keith Kelly
#2 posted 07-01-2014 01:39 PM
If you think that there is a chance that they will chew on them, then I would use shellac. It s what I use on baby cribs for that reason.
- Monte Pittman
That was a fast response.
No, I don’t think chair-chewing will be an issue.
View Bill White's profile
Bill White
4928 posts in 3954 days
#3 posted 07-01-2014 01:45 PM
Looks like ya got a pretty good finish on the little feller in the chair. :)
Why not just go with what ’s used on the table?
Bill
-- bill@magraphics.us
Keith Kelly
#4 posted 07-01-2014 01:55 PM
Why not just go with what s used on the table?
Bill
- Bill White
Good Q. I may. Spray-on sounds a lot easier, but maybe it’s not. Also, another table I refinished with wipe-on recently got a couple of scratches in it that are driving me nuts. I’m wondering if the wipe-on poly is advisable for chairs still (esp getting knocked against the table & other chairs so many times). If Lacquer spray will be easier and more maintainable, I may do that instead.
But, I’m not completely against doing the wipe-on…
View Earlextech's profile
Earlextech
1161 posts in 2684 days
#5 posted 07-01-2014 02:09 PM
For me – spray on poly – you wouldn’t have to worry about refinishing it until it gets passed on to their kids!
