Epoxy or Butterfly
Forum topic by crashman posted 07-01-2014 01:11 PM 1069 views 0 times favorited 6 replies Add to Favorites Watch
View crashman's profile
crashman
144 posts in 2309 days
07-01-2014 01:11 PM
Hello LJ’S, Looking for a bit of advice/experience. I am building a table top out of 2” thick book matched kiln dried Walnut. There is a knot on each side of the book matched table top with about a 4” crack from the drying process. My question is should I fill the crack w System 3 Epoxy? or inlay a butterfly across the crack to contain it, or maybe both?? The Walnut was kiln dried about 3 years ago so should be dry by now. I have no experience with this type of build & will appreciate any suggestions. Thanks in advance for your response.
-- Jack R. Ellis
View johnstoneb's profile
johnstoneb
2863 posts in 2136 days
#1 posted 07-01-2014 01:39 PM
I would do both. The epoxy will fill the crack. The butterfly will contain it and keep it from widening.
-- Bruce, Boise, ID
View Gary's profile
Gary
9324 posts in 3396 days
#2 posted 07-01-2014 02:00 PM
Agree
View DocSavage45's profile
DocSavage45
8519 posts in 2806 days
#3 posted 07-01-2014 03:33 PM
From what I’ve seen regarding this question: The suggestions to do both are what my first response was. A butterfly used to be called a Dutchman” as referenced to a functional repair. They have become symbols of added character, but it would really depend on the furniture style of the build.
I would practice doing both to see the results for myself in my skill in achieving it? LOL! And the overall look of the piece.
-- Cau Haus Designs, Thomas J. Tieffenbacher
View mahdee's profile
mahdee
3870 posts in 1731 days
#4 posted 07-01-2014 05:08 PM
You also can insert an inlay of say, cherry to fill the crack. I have a 3” thick walnut desk on my project where I used a piece of cherry to fill the void. You mentioned 4” crack, do you mean 4” long or 4” wide?
-- earthartandfoods.com
View bigblockyeti's profile
bigblockyeti
5090 posts in 1684 days
#5 posted 07-01-2014 05:14 PM
Have to agree with DocSavage, if the look suits the build and you don’t mind the extra work, then go for it. From a structure standpoint (assuming the crack isn’t very wide) epoxy alone should suffice, and it could be dyed too.
crashman
#6 posted 07-01-2014 09:45 PM
Thanks Guys. I am going to use some Cherry inlays in some other cracks in these slabs, just didn’t know how that would work in a knot, the crack is 4” long, maybe a little over 1/8th wide. I think I have made up my mind to do butterflies & epoxy both. Only want to do it once if you know what I mean…........................Thanks
-- Jack R. Ellis
