Help with cutting board handles
Forum topic by BlueVine posted 07-01-2014 12:28 AM 1222 views 1 time favorited 6 replies Add to Favorites Watch
View BlueVine's profile
BlueVine
4 posts in 1447 days
07-01-2014 12:28 AM
Topic tags/keywords: cutting board handles end grain router bit
Hi everyone. I just finished a bunch of end grain cutting boards. I am having trouble implementing handles. I’d like the boards to be reversible, so I would like to have handles like this. I tried using a rabbet bit, but it is impossible to get the bit low enough. I thought about using a round nose bit, but I don’t know how I could set the board up sideways to route the edges. Another idea was to use a dado set, clamp the board sideways, and slowly raise the blade, but that just seems really unsafe. Any ideas?? Thanks!
View AandCstyle's profile
AandCstyle
3050 posts in 2252 days
#1 posted 07-01-2014 12:41 AM
Take a look at these router bits. Maybe one of the larger ones will do what you want, HTH
-- Art
View Yonak's profile
Yonak
986 posts in 1516 days
#2 posted 07-01-2014 04:30 AM
View Purrmaster's profile
Purrmaster
915 posts in 2088 days
#3 posted 07-01-2014 11:25 AM
I’ve run into similar problems trying to cut handles into my cutting boards. I’ve found that the best bit for trying to carve it out is a spiral bit. The end result is not very elegant but it is serviceable.
View JimRochester's profile
JimRochester
515 posts in 1610 days
#4 posted 07-04-2014 04:24 PM
I would go with the round nose and set the board on edge. Just use stop blocks to get your length. Sneak up on it so the bit doesn’t grab the board from your hand.
-- Schooled in the advanced art of sawdust and woodchip manufacturing.
View waho6o9's profile
waho6o9
8188 posts in 2572 days
#5 posted 07-04-2014 05:55 PM
https://www.magnate.net/ProductDetails.asp?ProductCode=PG111
How about a fluting bit from Magnate?
View Dabcan's profile
Dabcan
255 posts in 2666 days
#6 posted 07-06-2014 12:49 AM
I do them with a core box bit I think it is called, basically a dome shaped bit, but I use a router table with a fence and a stop block on either side. Drop the board down, move till it hits one block, then slide to the other side. Depending on how deep the handles, you may want to do it in a few passes.
-- @craftcollectif , http://www.craftcollective.ca, https://www.etsy.com/shop/craftcollective?
