Cleanest way to apply glue?
Forum topic by Scootles posted 06-30-2014 08:17 PM 1186 views 0 times favorited 11 replies Add to Favorites Watch
View Scootles's profile
Scootles
153 posts in 1791 days
06-30-2014 08:17 PM
I’m going to be applying glue to some VERY small boxes. Glue squeeze out INSIDE the box will be impossible to clean up so I need to minimize it. How would you guys apply the glue cleanly and effectively?
11 replies so far
View TiggerWood's profile
TiggerWood
271 posts in 1482 days
#1 posted 06-30-2014 08:21 PM
I do a lot of small project glue ups. I use a cheap paint brush, paint the glue on thin, and leave the last 1/16” edge dry with the idea that what little squeeze out there would be will fill it in.
View Clint Searl's profile
Clint Searl
1533 posts in 2237 days
#2 posted 06-30-2014 08:30 PM
If you get squeeze out, you’re using too much glue.
View ShaneA's profile
ShaneA
6882 posts in 2474 days
#3 posted 06-30-2014 08:31 PM
You can prefinish as well, that way squeeze out can be wiped away easier.
Scootles
#4 posted 06-30-2014 08:36 PM
If you get squeeze out, you re using too much glue.
- Clint Searl
If you DONT have squeezeout you probably didn’t use enough. Squeezeout lets you know that the glue coverage is flawless inside.
View CharlesNeil's profile (online now)
CharlesNeil
2179 posts in 3747 days
#5 posted 06-30-2014 08:38 PM
Elmers glue all , dries clear, do it all the time, works great
View NiteWalker's profile
NiteWalker
2736 posts in 2453 days
#6 posted 06-30-2014 09:46 PM
If you DONT have squeezeout you probably didn t use enough. Squeezeout lets you know that the glue coverage is flawless inside.
- Scootles
This is what I was taught as well; if it’s dripping or running, then you’ve used too much. You want a thin bead to form. Then you know you got good coverage.
As for the OP’s issue, you can use tape on the inside of the joints to help reduce cleanup, and when applying glue, apply it towards the outside of the joint to minimize squeeze out on the inside.
View LYBeaulieu's profile
LYBeaulieu
14 posts in 1918 days
#7 posted 06-30-2014 11:24 PM
Just use painter’s tape to protect the area you want to spare. Works great on the inside to dovetailed drawers. I use that stuff in my shop all the time for a multitude of reasons like protecting my clamp bars.
Good luck!
LB
View gfadvm's profile
gfadvm
14940 posts in 2566 days
#8 posted 07-01-2014 01:21 AM
Prefinish the insides of your boxes with shellac taking care not to get any shellac on the areas to be glued. I just wipe on a couple of coats and it dries almost instantly.
View Jim Finn's profile
Jim Finn
2599 posts in 2798 days
#9 posted 07-01-2014 01:45 AM
If you are going to finish the inside of the box use Titebond liquid hide glue. When you apply a finish over the small amount of squeeze-out it will virtually disappear. I make a lot of boxes and apply Elmer’s white glue in a thin line and spread it away from the inside of the box with my finger. No squeeze-out.(on the inside) I do not finish the inside of these cedar boxes.
View RogerInColorado's profile
RogerInColorado
321 posts in 1830 days
#10 posted 07-02-2014 03:37 AM
I apply it with a plastic syringe I got at Woodcraft. Between applications I just drop it head first into a butter tub of water. With no back pressure, the glue just stays in the syringe, it doesn’t run out. The water keeps the glue from drying and clogging the tip. I’ve left one in the tub for weeks on end. It does not, by itself, solve the excess squeeze out problem. I’m an avid fan of spreading the glue, but most projects where the parts are small, I’ve found that controlling the amount of glue is easier with a syringe, and if the parts are small enough, I don’t need to be anal about spreading it across the width of the joint.
View ChefHDAN's profile
ChefHDAN
1007 posts in 2726 days
#11 posted 07-02-2014 06:43 PM
I cut a bevel on the end of a plastic drinking straw and use the straw to collect the squeeze-out from the inside corner and then a good wipe with a piece of wet non-woven fiber shop towel.
