MDF Template weight reduction(skeletonizing) question
Forum topic by InstantSiv posted 06-30-2014 12:01 AM 1067 views 0 times favorited 3 replies Add to Favorites Watch
View InstantSiv's profile
InstantSiv
262 posts in 1590 days
06-30-2014 12:01 AM
Topic tags/keywords: jig question router
Hi all,
I need to make a template. The size of the template is 23” x 50”. I have plenty of 3/4 mdf but no 1/2”. Since it’s 3/4” and I’ll be flush trimming 3/4” ply it’s going to be a monster to move around(I have to move it from one station to another for multiple processes).
I really don’t want to spend any money on 1/2” so I’m wondering how much material can I remove from the mdf template to lighten it before I run the risk of it breaking apart easily?
Here’s a pic of the template idea. The outside edges are suppose to be scalloped but it’s too much editing so I just left it straight.
3 replies so far
View jmartel's profile
jmartel
7882 posts in 2145 days
#1 posted 06-30-2014 12:12 AM
Whichever you decide, radiused corners are stronger than square corners. Just use say a 3/4” forstner bit at each corner and don’t square them off.
InstantSiv
#2 posted 06-30-2014 12:17 AM
Thanks for the tip. I’ll definitely do that. I have cheap set of hole saws that I’ll use to do the radius.
View bobkberg's profile
bobkberg
439 posts in 3069 days
#3 posted 06-30-2014 04:44 AM
If it’s just weight you are concerned about, I would recommend doing what airplane designers have done for decades… cut holes in the thing (not too close to any designed openings) to reduce the weight.
For example a 4” to 6” hole saw (leave at least 1 inch of material in the template at all points) might lighten up the weight enough to make it workable.
Having said that though, I would probably sand the whole thing and seal with 2 coats of varnish to prevent crumbling of the MDF from minor blows.
-- Bob www.singularengineering.com - A sideline, not how I earn a living
