Hex nut for faceplate
« back to Woodturning forum
Forum topic by kmetzger posted 06-28-2014 06:05 PM 1302 views 0 times favorited 9 replies Add to Favorites Watch
View kmetzger's profile
kmetzger
157 posts in 1783 days
06-28-2014 06:05 PM
Hello all, I’m planning to make my own faceplate using a 1×8 tip hex nut. I found one online that looks like it could fit my Jet 1441 lathe, but I don’t know what the “18-8” means. Would this nut work?
1”-8 18-8 Stainless Steel Finished Hex Nut
http://www.fastenal.com/web/products/details/70719?searchMode=productSearch&zipcode=&filterByStore=&filterByVendingMachine=
Here’s a video of the faceplate I’m going to make. It’s in Spanish but you can see what he’s doing if interested.
https://www.youtube.com/watch?v=DZYNYX4a05Q
-- Kim, Ajijic, Mexico, http://tinyurl.com/7w5fm25
9 replies so far
View Dallas's profile
Dallas
3599 posts in 2452 days
#1 posted 06-28-2014 06:16 PM
Grade 8 it is the hardness factor or the ability to keep from shearing. The 18 is at what particular set of tests the steel was put to.
kmetzger
#2 posted 06-28-2014 06:21 PM
Thanks, Dallas. Do you think this nut is the right size for my lathe?
Dallas
#3 posted 06-28-2014 06:24 PM
I don’t know as I have never seen one of your lathes before.
kmetzger
#4 posted 06-28-2014 06:58 PM
my Jet 1442 lathe
View TheDane's profile
TheDane
5399 posts in 3628 days
#5 posted 06-28-2014 08:02 PM
The nut you provided the link to appears to have the correct diameter and threads-per-inch, so it may fit. Assuming the thread depth isn’t a problem, it may work … the only way to tell for sure is try it.
I have heard of people making this type of faceplate, and it probably works okay so long as you take extreme care with it. Personally, I would never trust a faceplate with a metal-to-wood epoxy bond without some sort of mechanical connection(s). Maybe someone with experience using this sort of faceplate can chime in with more authoritative advice.
View bondogaposis's profile
bondogaposis
4683 posts in 2316 days
#6 posted 06-28-2014 09:41 PM
It looks to me like it would work.
-- Bondo Gaposis
View JamesVavra's profile
JamesVavra
304 posts in 3281 days
#7 posted 07-14-2014 05:26 PM
18/8 is a reference to the ratio of chromium and nickel in the stainless steel, in this case, 18% chromium, 8% nickel. (see: http://en.wikipedia.org/wiki/Stainless_steel) The threading is correct for the spindle on your lathe.
I don’t think I’d make a faceplate out of stainless – I’d use a softer metal like brass or aluminum to ensure the faceplate didn’t damage the threads on my spindle.
Another option that would give you a lot more bang for your buck (assuming you intend to make a few of these) is a tap that fits your spindle: http://www.amazon.com/Beall-Tools-TPI-Spindle-Tap/dp/B0037MAR1U – this is what I used to make faceplates when I had a Jet 1442 and it worked very well. When I moved up to a larger lathe with a bigger spindle, I bought the exact same tap in the appropriate size.
James
View Knothead62's profile
Knothead62
2584 posts in 2926 days
#8 posted 07-14-2014 07:26 PM
What JamesVavra said.
View simmo's profile
simmo
67 posts in 3437 days
#9 posted 07-15-2014 05:53 PM
Hi I have a lathe with 1”/8tpi thread,I have been making wooden sacrificial faceplates that can be glued directly onto the base of projects amongst a myriad of other uses,I have a 12” sanding disc from a hardwood boss glued to a laminate worktop disc, made it in 1983 still in use today HTH
Chris
