Dips in a rabbet using a router table (for a picture frame)
« back to Joinery forum
Forum topic by LotsToLearn posted 06-28-2014 04:26 PM 2123 views 0 times favorited 12 replies Add to Favorites Watch
View LotsToLearn's profile
LotsToLearn
6 posts in 1397 days
06-28-2014 04:26 PM
Topic tags/keywords: rabbet router dips problems pine router table technique beginner picture frame bit straight bit
I’m fairly new to using the router and hoping that someone can explain the error of my ways. In photo below, you’ll see the problems I had routing a rabbet in the side of my pine picture frame. (I cut the miters after routing because it seemed easier to push the piece through on the router table with square ends).
For the artwork being framed, I needed a 3/4” wide, 1/2” deep rabbet. I didn’t have a rabbet bit, but I had a 3/4” straight bit. So, what I tried to do was to put the frame side on its edge and make multiple passes on the router table, deepening the rabbet by moving the fence out with each pass until it had the 1/2” depth.
I had twelve pieces that I worked this way. What you’ll see in the photo is one piece where the result is not clean. I had eight or so fairly clean pieces. I think the bad work is what the author of:
Rabbet Joints with a Router
calls “wobbles and dips”.
Any thoughts on what might be causing the dips in the piece? I used one push stick on the end and one on the side of each piece as I moved it through the router bit.
I appreciate the help.
12 replies so far
View NiteWalker's profile
NiteWalker
2736 posts in 2545 days
#1 posted 06-28-2014 04:41 PM
Looks like the router bit is chattering, usually indicative of too big a bite. The fence could also be slipping.
View Mas's profile
Mas
57 posts in 2230 days
#2 posted 06-28-2014 04:43 PM
Since you were using a push stick to keep it up against the fence, it looks to me that you may have been pushing harder at times causing the board or fence to flex.
if you can use a feather board to keep consistent pressure and that may help get rid of most of the dips
View bondogaposis's profile
bondogaposis
4687 posts in 2319 days
#3 posted 06-28-2014 04:47 PM
I agree w/ the above posts, another thing to consider is that a 1/2” shank bit is going to give you better stability than than 1/4” shank bit pictured.
-- Bondo Gaposis
LotsToLearn
#4 posted 06-28-2014 04:53 PM
I wouldn’t doubt that I applied uneven pressure with the push stick that pressed the piece against the fence. I’ll look into the feather board, especially as I plan to be doing a lot more of this in the future.
I’m using a homemade router table (cabinet) so I’ll look at good ways to attach the feather board.
I appreciate the comments.
View NoThanks's profile
NoThanks
798 posts in 1497 days
#5 posted 06-28-2014 04:58 PM
It’s easier, in my opinion, to cut them out with the table saw.
I think your board was moving in and out every time you stopped the cut while you were pushing it through.
Notice that most of the bumps are towards the end after the material was removed making your pc more unstable against the fence as you pushed through. (letting your pc rock)
You need a feather board as tall as the frame to keep the pc parallel as your pushing through.
EXAMPLE:
-- Because I'm gone, that's why!
View cabmaker's profile
cabmaker
1723 posts in 2777 days
#6 posted 06-28-2014 05:06 PM
Appears that your setup may not be evacuating chips quick enough to keep the way slick and smooth
As stated, table saw would be a more efficient method
JB
View Pezking7p's profile
Pezking7p
3217 posts in 1619 days
#7 posted 06-28-2014 05:28 PM
I disagree with what most above posted. In order for your router bit to cut deeper, it must move further into the wood. Therefore it is not failure to evacuate chips, or uneven pressure.
It is unlikely that your fence or router bit are flexing the 32nd – 1/16th shown in your pic. I think something in your router table is loose, and when the bit get a little harder bite it pulls your router up out of its mount and into the wood. My router, for instance, just sits in an insert in my tables saw extension and there is nothing to stop it from pulling up out of the table. If this were happening on my router, I would start by bolting my insert to the table saw extension instead of just letting it sit inside the inset.
Check your router/lift/insert/fixed base for any movement or wobbles, secure everything. I bet that solves it.
-- -Dan
Pezking7p
#8 posted 06-28-2014 05:38 PM
Ok I changed my mind after looking closer at your pic. It looked like at those points the bottom of your piece was pressed into the router bit. Solve by applying pressure to only the part that is not being cut.
-- -Dan
NoThanks
#9 posted 06-28-2014 05:55 PM
- Pezking7p
Exactly, the spacer block behind the bit will help keep that from happening
NiteWalker
#10 posted 06-28-2014 05:58 PM
I just noticed you did the cuts on edge; doing them face down would result in a more even cut.
View Rutager's profile
Rutager
27 posts in 2271 days
#11 posted 06-28-2014 05:58 PM
Routing the rabbet with the board on the edge is giving you so little support, that it will be almost impossible to keep it stable, I would instead rout it flat and move the fence over a couple times to get the width. The other benefit will be that the bit doesn’t have to stick up as high, giving less flex and making it safer. Use a push block to give downward pressure and to keep your hands away from the bit.
LotsToLearn
#12 posted 06-28-2014 08:02 PM
great advice – thanks again!
