Planer sled
Forum topic by ajthomas5009 posted 06-28-2014 03:05 AM 1110 views 0 times favorited 3 replies Add to Favorites Watch
View ajthomas5009's profile
ajthomas5009
296 posts in 1612 days
06-28-2014 03:05 AM
Hi all I’m in the middle of making some planer sleds for milling purposes. I planned on making a 8’, 5’ and 3’ sled all similar to one featured in FWW a few years back. For the base I was going to go with 3/4” MDF sandwiched in between 2 pieces of B-Birch ply. My problem is that I don’t want to spend 80$ in just sheet goods. I have enough birch lying around for the 6’ and 3’ sleds and want to know if there is any reason why I shouldn’t use (3) 3/4” pieces of MDF on the longer sled to cut down on costs?
I know it prob can be done just looking for a little advice before I hack up a whole sheet of MDF.
-- Sometimes you're flush and sometimes you're bust, and when you're up, it's never as good as it seems, and when you're down, you never think you'll be up again, but life goes on.
3 replies so far
View bigblockyeti's profile
bigblockyeti
5112 posts in 1715 days
#1 posted 07-02-2014 10:48 PM
MDF isn’t nearly as stiff as BB and could result in sagging sometime down the road. It would also need greater support on the in feed and out feed side of the planer, again to keep the lamination from sagging. In addition to the increased potential for greater sagging, it would also be heavier. If you’re not concerned with this lasting forever, it might not be bad idea if you’re ok with spending more on materials if/when the all MDF sled can no longer suit your needs.
View Rhwoodworks's profile
Rhwoodworks
18 posts in 1421 days
#2 posted 07-02-2014 11:29 PM
I try to use baltic birch for most of my jigs.. sand the top smooth and wax it with butchers or something ..Then hand buff it and it will work great..
Rhwoodworks
#3 posted 07-02-2014 11:30 PM
