The big box stores seemes a little high for wipe on poly to me .
Forum topic by eddie posted 06-27-2014 07:40 PM 1310 views 0 times favorited 26 replies Add to Favorites Watch
View eddie's profile
eddie
8565 posts in 2523 days
06-27-2014 07:40 PM
the big box stores seemed a little high for wipe on poly to me .So i was wondering can you take poly and make your own and what mixture would be best?
-- Jesus Is Alright with me
26 replies so far
View lightcs1776's profile
lightcs1776
4189 posts in 1564 days
#1 posted 06-27-2014 07:43 PM
Eddie,
I just mix my own, but I’m pretty low tech. I do about a 50/50 mix and use several coats. I’ve done it this way a few times and like the results.
-- Chris ** If there must be trouble, let it be in my day, that my child may have peace. — Tom Paine **
eddie
#2 posted 06-27-2014 07:47 PM
thanks Chris ,ive used wipe on when i cant get outside and use my spray rig .but went to get some and its too much for a small can ill start mixing it up what did you use ?
lightcs1776
#3 posted 06-27-2014 07:53 PM
I just mixed it with mineral spirits, based on someone’s post here and some Internet research. The ratio didn’t seem to be all that important, although the thinner it is the more coats you will need to apply. I mixed mine in a plastic disposable bowl, since I knew I was going to keep putting on coats until it was gone. I think I used Minwax for the polly, whatever the gallon size is at Home Depot.
View William's profile
William
9949 posts in 2752 days
#4 posted 06-27-2014 07:54 PM
Eddie, I use 50% minwax poly and 50% mineral spirits.
It costs a lot less and works exactly like the high dollar quarts they sell at the local hardware stores.
lightcs1776
#5 posted 06-27-2014 07:56 PM
Come to think of it, it might very well have been one of William’s posts where I got the idea.
eddie
#6 posted 06-27-2014 08:04 PM
thank yall im not buying anymore premixed ,around 13 bucks for a small can quart i think .
View Monte Pittman's profile (online now)
Monte Pittman
28238 posts in 2248 days
#7 posted 06-27-2014 10:08 PM
Glad you posted this. I was just standing here complaining.
-- Mother Nature created it, I just assemble it.
View gfadvm's profile
gfadvm
14940 posts in 2600 days
#8 posted 06-28-2014 12:28 AM
eddie, I mix mine a bit thicker: 1 part MS to 2-3 parts Spar (if I’m looking to add a little amber) or Poly. I have also added stain to this mixture to further eliminate a finishing step. Finished all the woodwork in my daughter’s clinic with Gunstock Stain/Spar/Mineral Spirits wipe on. Worked great and was quick!
eddie
#9 posted 06-28-2014 01:19 AM
thanks Andy i will try the mix ,that would be a lot faster
eddie
#10 posted 06-28-2014 04:22 PM
Monte its better to sit and complane . unless its a dull blade on the plane :)
View bondogaposis's profile
bondogaposis
4611 posts in 2261 days
#11 posted 06-28-2014 04:55 PM
50:50 mix of regular poly and MS works for me. I also like increase the ratio of poly to MS to 75:25 on the last 2 coats to get a better build.
-- Bondo Gaposis
eddie
#12 posted 06-28-2014 09:11 PM
thanks Bondo Gaposis will yry this on the last two coats
View bbc557ci's profile
bbc557ci
595 posts in 1984 days
#13 posted 06-28-2014 09:23 PM
I’ve never used a wipe on so these might be silly question?....
What do you use to wipe it on with, old cotton t-shirt, old wash cloth, old towels?
Also, can the quick dry type poly be used?
-- Bill, central NY...no where near the "big apple"
lightcs1776
#14 posted 06-28-2014 09:30 PM
I’ve used an old t-shirt as well as a paper towel, and they worked pretty well. I also used an old towel, but it left lint.
View TheFridge's profile (online now)
TheFridge
8912 posts in 1396 days
#15 posted 06-28-2014 10:12 PM
You think wipe on poly is expensive, try buying rebar.
