06-27-2014 12:12 AM
Topic tags/keywords:
table
redwood
black walnut
chevron
question
help
sander
I started this project a few months ago. As time permits I get to do a bit of wood working. I started this project with a simple goal, to prove to a local friend that redwood fence slats could be turned into a beautiful piece of furniture. So, off I went and picked up 40 redwood fence slats from Home Depot. About a month of dry time, hours spend cleaning up the boards on the jointer, table saw and surface planer later, I had some really good looking wood. Below you will see the nearly finished top. I need a few more coats of poly and it will be done. I am relatively happy with the results but would like some advice. After gluing in the the top layer of chevrons, the surface was pretty flat. All wood had been planed to the exact same size. After a bit of putty work on a few cracks, I started sanding. I noticed very quickly that I was developing small “waves” in the wood. These waves settled in along the grain pattern and became more noticeable as I sanded. To do the sanding, I used the RIDGID 6” random orbital sander. This was my first project using this sander and it worked very well, even on the 1/8” orbits on a very slow speed.
How do I get rid of these waves next time I make a desk or table?
Thanks!
-- J.D. Williams
14 replies so far
#1 posted 06-27-2014 01:26 AM
JD, Redwood is pretty soft, so I don’t think you’ll get away without sanding deeper into the sofert grain as apposed to the hard grain. I had a friend that built his cabinets using Doug Fir plywood for the doors. He and his wife had over a 100 hours sanding those doors just to get the effect you are getting accidentally…. Oh well…........ Jerry (in Tucson)
#2 posted 06-27-2014 01:34 AM
Jerry gave the answer I was going to give so I’ll just add: GREAT looking table top!
#3 posted 06-27-2014 01:45 AM
Yeah, what nubs said. Redwood is soft, but not consistently so. The more you sand the more you erode the soft areas. The table looks great btw, to avoid the waves use a hardwood.
-- Bondo Gaposis
#4 posted 06-27-2014 01:49 AM
Use hand planes and scrapers.
#5 posted 06-27-2014 02:15 AM
Thanks for the compliments and suggestions. Much appreciated. I will post final pictures in a few days…
-- J.D. Williams
#6 posted 06-27-2014 02:24 AM
If you want flat, you have to use a platen a lot bigger than a 6” diameter disc. You could use a sander that has at least one sheet of area, or a long board, and keep it moving over the entire surface, not just sanding one area that appears rough. This works for glass-smooth auto finishes, but you may not want to go that extreme. I’ve made wood projects stone flat using this method. I use a long straightedge, and even a laser to check flatness, to install machinery that has to be dead flat to within a few thousandths over many yards. It takes patience, believe me. I have hand-scraped flooring in my house, because it is what my wife likes. I can do that too, but in this case, I bought it, as I don’t have time for it, doing my regular job (mechanical engineer).
-- Random Orbital Nailer
#7 posted 06-27-2014 02:39 AM
#8 posted 06-27-2014 03:11 AM
Would something like this do the trick?
http://www.ebay.com/itm/Rockwell-Porter-Cable-505-Half-Sheet-Finishing-Sander-/131223969375?pt=Sanders_Sandblasters&hash=item1e8d8ede5f
- JDWilliams
I don’t think so. I replaced one of those with a 5” ROS and found it far superior.
A stroke sander might help. Good excuse to buy one to see. :^)
#9 posted 06-27-2014 03:20 AM
Cabinet scraper bud. I use on softwoods like cypress all the time. It’s a lot of elbow grease but the scraped surface needs very little sanding.
#10 posted 06-27-2014 03:23 AM
TheFridge – could you shoot me a link to what you are suggesting?
-- J.D. Williams
#11 posted 06-27-2014 03:31 AM
#12 posted 06-27-2014 07:24 AM
You pretty much have your answer. Just wanted to say, beautiful table top. .
-- Mother Nature created it, I just assemble it.
#13 posted 06-27-2014 09:02 AM
Forgot, Welcome to Lumberjocks
first thing to learn, wood is rarely perfect. Enjoy the journey of learning how to deal with it.
#14 posted 06-27-2014 01:04 PM
http://www.leevalley.com/en/Wood/page.aspx?p=68491&cat=1,41182
Welcome to Lumber Jocks and that’s a fine looking red wood
table top!
Forum |
Topics |
Woodworking Skill Share
Your woodworking skills are displayed for several lifetimes in each project. Have you had to compromise your project...
12033 |
Woodturning
On the lathe, by the lathe: do you have questions? frustrations? tips? This forum is for all the woodturners out there.
2108 |
Woodcarving
Relief, 3D, chip-carving, whittling; carving knives, chisels, pocket-knives, power tools. If you are a carver or want...
431 |
Scrollsawing
Intarsia, fretwork, intricate design cutting and more! This forum is for scrollsawers: share your tips, ask questions...
340 |
Joinery
Have a question? a tip/strategy to share? a challenge, perhaps? Share your "joinery" discussion here.
1370 |
Finishing
The finish, whether paint, wax, stain, or something else, can make or break a project. What are your tips and questio...
4906 |
Looking for information on designing your projects? Having difficulties reading project plans? Looking for help with ...
6696 |
Are you unsure of which tools, or hardware, you need, or which brands to buy? Investing in tools and hardware can be ...
28065 |
CNC Woodworking
Questions and answers about CNC machines, tooling, best practices, and projects.
212 |
Hand Tools
Wood, your hand tools, you and a little know-how. Share your questions, tips and strategies for the use and maintenan...
5412 |
Jigs & Fixtures
Using a jig is like having a couple extra hands helping out. Show us your jigs, share your tips, strategies and, of c...
1420 |
Wood & Lumber
Different wood requires different woodworking strategies - from cutting to finishing. Share your tips and challenges ...
6233 |
Before you pick up those woodworking tools, take the time to ensure your safety in the shop! Eyes, ears, fingers, and...
1389 |
Focus on the Workspace
Are you looking for or do you have tips to share regarding the workshop? Storage, equipment placement, efficiency, an...
2154 |
If you are selling your work, then you have entered a woodworking dimension with added complexity and stress. If you...
1187 |
Woodworking Trade & Swap
All of us are holding onto treasure in our shops, that we either don't need, don't want, or could part with if presen...
4758 |
LumberJocks.com Site Feedback
Connect with the Website Gurus and tell us what you are thinking, suggestions, problems, functionality issues, and so...
2200 |
Coffee Lounge
Need a break from all the standing and wood dust? Chat with your Forum Friends about their projects, their life, thei...
8846 |
