Waxing Bessey parallel clamps?
Forum topic by ScoFF posted 06-26-2014 04:33 PM 1569 views 0 times favorited 8 replies Add to Favorites Watch
View ScoFF's profile
ScoFF
21 posts in 3434 days
06-26-2014 04:33 PM
Before I try it on my clamp I’d like to know if putting wax in the teeth willmake it slip or not grab when I tighten it. I have several other brand F-style clamps I tried this on and I couldn’t tighten them anymore, they just kept slipping and wouldn’t grab. I had to remove the wax. They had the same teeth style rail edge as the Besseys but might use a different method of grabbing them.
-- ...I will not be limited.
8 replies so far
View Bill White's profile
Bill White
4853 posts in 3863 days
#1 posted 06-26-2014 04:36 PM
No wax on clamps. Period!
Bill
-- bill@magraphics.us
View danofpaco's profile
danofpaco
118 posts in 1819 days
#2 posted 06-26-2014 05:24 PM
I have waxed my Bessey’s – no issues with clamping and helps protect them from squeeze out.
-- Dan :: Minnesota
View paxorion's profile
paxorion
1107 posts in 1948 days
#3 posted 06-26-2014 05:31 PM
I’ve waxed all my clamps and had no issues. I use Crystal Clear Paste Wax
-- paxorion
View gtbuzz's profile
gtbuzz
427 posts in 2344 days
#4 posted 06-26-2014 05:48 PM
I also wax the rails on my Bessey parallel clamps (K-body Revos and Uniklamps) to protect them from squeezeout. Never had any issues with clamping force, but I’d definitely like to see what other people have to say in case i’m really doing something wrong.
View pintodeluxe's profile
pintodeluxe
5565 posts in 2716 days
#5 posted 06-26-2014 06:15 PM
If your clamps aren’t sliding well, check the black plastic caps on the clamp head. I have noticed some of mine don’t allow any clearance between the black cap and the metal bar. A little filing on the slot in the black cap can fix the issue.
I haven’t had any issues with glue sticking to the bars, but I would be hesitant to wax clamps for the reasons you mentioned above.
View jonah's profile
jonah
1572 posts in 3201 days
#6 posted 06-26-2014 07:37 PM
I wax my parallel clamps. No issues.
Bill White
#7 posted 06-26-2014 08:20 PM
Oh Well….....
I tried.
Wax away if ya wish. I just don’t see the value of the effort.
Having said that, I don’t wax my head either.
Now, waxing cast iron surfaces is a different issue, and we don’t wanna get that subject goin’ again. :)
Bill
View DrDirt's profile
DrDirt
4421 posts in 3644 days
#8 posted 06-26-2014 08:51 PM
Wax on the parallels is just fine, the teeth on the bar will still hold.
If you hav trouble – just clean it off.
Helps keep the glue off, which is more of a PITA in the teeth of the bar to me.
Some F body clamps can slip with a smooth bar… I have never had slippage of any waxed clamps.
I have never waxed quick grip/Irwin clamps
