What a Difference a Good Saw Blade Makes!
Forum topic by knotscott posted 06-26-2014 11:58 AM 5687 views 2 times favorited 17 replies Add to Favorites Watch
View knotscott's profile
knotscott
8147 posts in 3576 days
06-26-2014 11:58 AM
Topic tags/keywords: tip resource
My son needed to cut some reclaimed pine from an old waterbed and I was concerned about encountering staples, nails, screws, etc., so I dug out an Irwin Classic 40T blade, cleaned it, and tossed it on the saw. I could hear the difference from the second I turned on the saw. It rang, zinged, whined, and ticked my ZCI due to blade runout. The sound from hitting the ZCI gave way after a while, but the ringing sound of cheap steel remained, and made a zinging sound at the end of each cut that was reminiscent of a circular saw. The cut quality was pretty poor…the blade wasn’t new, but was clean, and didn’t appear to have been used much, so I assume it was fairly sharp. What a turd that blade is! That prompted me to pull out 60T Avanti “junk” blade I had on hand (not the Freud Avanti), and got pretty similar results.
It’s been more than 10 years since I’ve used anything less than a very good saw blade on my TS, CMS or circ saw for woodworking purposes. I’ve been preaching buying good blades for a decade or so since I learned that lesson the hard way, but this experience was a flagrant reminder that there IS a huge difference between a well made blade, and cheap blades like those that come stock on most saws and many of commonly found aftermarket blades at homecenters. There’s such a blatant difference….I’ll keep preaching!
Buy – Infinity, Forrest, Ridge Carbide, Tenryu Gold Medal, Freud Indstrustial, CMT Industrial, Leitz Pro, Everlast, Systimatic, Amana Tool, Guhdo….on a budget buy Freud Diablo, Irwin Marples, CMT ITK Plus, Tenryu Rapid Cut, Oshlun, DeWalt Precision Trim, discontinued Delta Industrial, Onsrud, etc. on clearance. There are some really good 10” blades for as little as $18 if you know where to look! $30 buys a good 10” blade every day from HD or Lowes.
Avoid (for fine woodworking grade cuts) – DeWalt Construction, Oldham Contractor, Avanti/Avanti Pro, WorkForce, Ryobi, HF, Vermont American., Skil, most Sears, Irwin Classic, Irwin Marathon, and most construction grade multi-packs. These have their place, but… If you do any remotely fine woodworking, and go to any lengths at all to make your saw the best it can be, avoid these blades.
Saw Blade Bargains
The ABCs of Picking Saw Blades
17 replies so far
View reelman65's profile
reelman65
35 posts in 2880 days
#1 posted 06-26-2014 12:15 PM
thanks for the insight,
View The Box Whisperer's profile
The Box Whisperer
678 posts in 2271 days
#2 posted 06-26-2014 12:26 PM
You tell the truth! While on the subject, Id like to get a new blade for my dewalt 12” miter saw. I use a Forrest WWII on my table saw and love it, but find 150 bucks a tough pill to swallow for the 12” chopmaster. What are you recommending these days for a good, 12” cross cut blade under 100 bucks?
EDITED: Just noticed your link to saw blades so Im checking that now. Is this new? Ive read yoru ABCs a few times but never noticed this.
-- "despite you best efforts and your confidence that your smarter and faster than a saw blade at 10k rpm…. your not …." - Charles Neil
View b2rtch's profile
b2rtch
4867 posts in 3249 days
#3 posted 06-26-2014 12:27 PM
Thank you for the reminder
-- Bert
knotscott
#4 posted 06-26-2014 12:45 PM
- JoeGrant78
Hi Joe – I added the blade bargain bit about a year ago….not many top flight 12” blades on it though, as I was trying to keep them all near the $40 mark and under.
I’d take a good look at the Infinity 012-090. Similar design as the Chopmaster, $109 before any discounts (check their specials). They make some great blades, but I haven’t tried this one. The CMT 210.096.12 could be a good choice for fine cuts too ($95)....I’ve tried the 00210.080.10, but not the 12” version.
The Box Whisperer
#5 posted 06-26-2014 02:20 PM
awesome thanks!
TheWoodenOyster
1317 posts in 2136 days
#6 posted 06-26-2014 02:31 PM
Knotscott,
Just yesterday I used my two industrial Delta blades that I bought from cripe distributing off of ebay. You recommended them to me a few months ago and I just got around to ordering them. They are stellar blades and I thank you for your insight and recommendation. The teeth on those blades have a ton of life in them and they are quality blades. Thanks again.
-- The Wood Is Your Oyster
View Ripthorn's profile
Ripthorn
1458 posts in 3186 days
#7 posted 06-26-2014 02:57 PM
This same fact holds true for bandsaws as well. I just put a timberwolf blade on after 4 years of trying different blades, tires, springs, guides, etc. The thing now cuts like a respectable saw, finally!
View bandit571's profile
bandit571
21760 posts in 2884 days
#8 posted 06-26-2014 03:12 PM
With the stuff I ran through the tablesaw and now the circular saw, Not looking for anything close to finish ready cuts.
We are talking nail-infested BARN WOOD and Barn Beam & Rafters. Found the “tang of one old tool in a rafter, found a LOT of buried cut nails, and a couple of bullets, including one that hadn’t been FIRED! At least I saw THAT little gem before the saw did.
So, with all the ripping down going on, and a tooth flying by now and then, I’m NOT spending a ton of cash of a couple rip blades. Put a couple under $20 irwin rip blades to work. Cheap enough that a “PING” now and then is going to break the bank. I tend to finish all edges with another type of “Jointer”
IF you look close, you will see some of the Barn wood I work with. A Stanley #31 from about 1882….
View Rob's profile
Rob
704 posts in 3271 days
#9 posted 06-26-2014 04:48 PM
I had the same experience with my circular saw a couple years ago. The Skil-brand blades I was using were noisy and didn’t cut well. The plywood blade would bind up constantly, and was guaranteed to come to a halt as soon as it touched my sacrificial support piece if I set it more than about 1/8” deeper than my 3/4” OSB or plywood.
I upgraded to a Freud thin kerf blade which is so quiet and cuts so well that I usually can’t even tell when it enters the wood now. I don’t think it has bound up once.
-- Ask an expert or be the expert - http://woodworking.stackexchange.com
View LeTurbo's profile
LeTurbo
232 posts in 1786 days
#10 posted 06-26-2014 05:37 PM
Thanks for this … I’ve created a reminder Word doccie for myself called “Good and Bad Saw Blades”. (And I probably should replace mine soon anyway.)
View jonah's profile
jonah
1921 posts in 3499 days
#11 posted 06-26-2014 07:44 PM
I agree with just about everything knotscott said. I have a few junk blades that I use for cutting rough stuff, and I’m consistently amazed by how poorly they cut compared to my Forrest or Matsushita blade.
View Joe Lyddon's profile
Joe Lyddon
10321 posts in 4253 days
#12 posted 06-26-2014 10:11 PM
YES!
View DIYaholic's profile (online now)
DIYaholic
19708 posts in 2876 days
#13 posted 06-26-2014 10:29 PM
Knotscott,
I defer to your recommendations, or I will when I buy top quality blades….
I’m using the Irwin Marples blades in my TS & SCMS.
Nice post… Reaffirmation is never a bad thing!
View Dusty56's profile
Dusty56
11822 posts in 3889 days
#14 posted 06-26-2014 10:37 PM
Good to hear from you again, KnotScott : ) I purchased an Irwin Marples 10” for my TS due to some high praise that was found on this site, but wasn’t impressed with the cut quality it gave me. I put my Freud blade back on and there it stays : ) Believe it or not, I got a couple of Porter Cable branded blades for not a lot of money and their cut quality was better than the Marples. I was quite surprised as I had bought them for use on less demanding projects : )
Have a Happy Fourth of July !
View gfadvm's profile
gfadvm
14940 posts in 2891 days
#15 posted 06-27-2014 01:26 AM
I would add that the DeWalt “Ultra Thin Kerf” 7 1/4” are a very worthwhile investment for use in a circular saw that is underpowered as well as in the table saw when a very thin kerf is desired. I use those in my old plastic B&D when reclaiming barn wood with nails.
