| Forum topic by chippytippy | posted 304 days ago | 619 views | 0 times favorited | 13 replies | ![]() |
304 days ago |
Hi guys, Well I’m a bit stumped on a project I am working on and before I really mess it up I thought I would check in here and get some feedback. I just glued up a small panel that is going to be the top of a jewlery box. Now I need to plane it as the boards shifted a bit and are not perfectly level. I do have Ridgid surface planer but I opted to use my bench plane (no 4 stanley) as I am sure this is a skill I need to develop. I didnt realize it would be so difficult to get a smooth surface. I cant seem to get the plane to run from one end of the panel to the other without tearout or shagging on something. Is this mainly do to the fact the the grain runs in different directions on each board? There are only three boards, with alternating end grain and I am using ash. So how do you surface a panel that has several boards, each with a different dirrection inwhiich the grain is running? Thanks in advance!! Chippytippy |
