Jointer Knives - a bit of a pickle
Forum topic by Mars72 posted 06-25-2014 11:23 PM 1654 views 0 times favorited 7 replies Add to Favorites Watch
View Mars72's profile
Mars72
33 posts in 3456 days
06-25-2014 11:23 PM
I have an older American WJ-6 Jointer that I inherited. It was poorly maintained. The knives were never replaced or sharpened. So, in my zeal one of the first things I did was to remove the knives for sharpening without marking any kind of top dead center. The fence is funny on this in that it is cut out above the cutter head and outfead table about an inch. I purchased Rochlers knife setting jig. Iam having trouble finding the tdc. Any clues?
-- I usually try the hard way 2 or 3 times before finding the easy way.
7 replies so far
View pintodeluxe's profile
pintodeluxe
5798 posts in 3017 days
#1 posted 06-25-2014 11:34 PM
Place masking tape over the fence cutout. Reinstall one knife. Mark TDC on the masking tape.
View MrUnix's profile
MrUnix
7051 posts in 2402 days
#2 posted 06-26-2014 12:04 AM
Simple if you have a dial indicator.
View Babieca's profile
Babieca
178 posts in 1708 days
#3 posted 06-26-2014 12:52 AM
I’ll second the dial indicator. Could not have replaced my jointer knives without one.
View giser3546's profile
giser3546
179 posts in 1676 days
#4 posted 06-26-2014 01:54 AM
Ill also give a recomendation for the dial indicator. I tried setting up my planer with feeler gauges and couldnt get it anywhere as close as i can with the feeler gauge. Getting one with a base will cost you about $100, but harbor freight has one without a stand for $15.
-- "If you wait for it to rain, It will"
Mars72
#5 posted 06-26-2014 02:07 AM
Saw that at HF. I’ll pick one up with a magnetic base this weekend.
MrUnix
#6 posted 06-26-2014 02:12 AM
Indicator, magnetic base and set of tips complete with protective case for under $30 at Amazon.
runswithscissors
2895 posts in 2229 days
#7 posted 06-26-2014 04:06 AM
TDC is precisely straight up from the center point of the cutter head. Once you’ve determined where that is, you can scribe a line on the fence so you won’t have to hunt for it every time.
