Large Radius Circle Cutting with Jigsaw
Forum topic by RHH posted 06-25-2014 03:30 PM 1326 views 0 times favorited 4 replies Add to Favorites Watch
View RHH's profile
RHH
23 posts in 3889 days
06-25-2014 03:30 PM
I need to cut some plywood arcs to make a couple of conduit bending jigs. One of them requires a 25-1/4” radius. This cannot be done with the circle cutting jig that came with my Bosch barrel grip jigsaw. It has a limit of ~16”.
Yes, I could build a jig and cut circles with my router, but the jig building time is onerous. I have the jigsaw and it should be more than adequate but I’m scratching my head to figure out how to get an extended radius. I have to make 4 different arcs for this project.
Ideas? Suggestions? What did you do?
-- RHH - Temple, Texas, USA
4885 posts in 2402 days
#1 posted 06-25-2014 03:44 PM
I would probably get a piece of steel stock that approximates the size of the arm on the circle cutting jig (but one long enough for your needs), clamp to the jig saw and go.
View nailbanger2's profile
nailbanger2
1041 posts in 3052 days
#2 posted 06-25-2014 03:50 PM
Depending on how accurate this needs to be, you can A) take a thin ~ 2” wide strip of ply and square one end. Measure 25.25” down the center and put a nail or screw or pin there. Put the nail in the center of your circle, then scribe the arc at the squared end. Use your eye and jig saw to cut a pretty good, not perfect, arc. or B) take the same strip and cut perpencicularly about an inch in from the end. Measure 25.25” from the inside of this cut down the center. Put a nail there and pin it to your plywood center. You now have a trammel. Go slow or your jigsaw will drift on the bottom side of the cut.
Hope this helps. Oops, forgot to say, attach ply to the jigsaw with a screw or two.
-- Wish I were Norm's Nephew
View RHH's profile
RHH
#3 posted 06-25-2014 06:31 PM
Good suggestions!
Thank you.
Will take a look at Lowe’s for some metal bar.
View bondogaposis's profile
bondogaposis
4611 posts in 2260 days
#4 posted 06-25-2014 07:26 PM
A strip of 1/4” MDF and double stick tape and a nail is all you need for jig.
-- Bondo Gaposis
