Forum topic by generic | posted 06-25-2014 03:48 AM | 1160 views | 0 times favorited | 11 replies | ![]() |
Topic tags/keywords: humor tablesaw OK, I will admit I’m easily amused. I try to use a cheap 10” blade to rip dimensional lumber or to cut stock to to a rough size. When it comes down to making the final wdith cuts, I switch blades. Even though I have had my saw for awhile now, I’m still find it amazing the difference in blade size between a standard 10” blade And a 14” blade |
11 replies so far
#1 posted 06-25-2014 05:04 AM |
Probably not alot of comments forthcoming. |
#2 posted 06-25-2014 09:29 AM |
You’ll be even more amazed if you clean the pitch off that blade! -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
#3 posted 06-25-2014 10:59 AM |
Unbob- I really didn’t expect any comments. It was just late and I was amused. Lol Knotscott – the blade came with the saw when I bought it. The previous owner used it to resaw 12/4 Brazilian Cherry and never cleaned the blade hence why it looks so bad. I agree, it needs to be cleaned again, but i got home late from work and opted for working time versus cleaning time. Especially since it was still cutting clean and smooth. |
#4 posted 06-25-2014 11:15 AM |
Cleaning is what shrinks them like that! Have to be careful to only use cool water, woolite, and line-dry. -- You've got to be smarter than the tree. |
#5 posted 06-25-2014 12:00 PM |
That’s what does it? I figured it had something to do with drying them on high. Either that or sharpening them too many times. ;) |
#6 posted 06-25-2014 12:36 PM |
Kept trying to shrink my blades, but the dryer died before I could finish. -- Shooting down the walls of heartache. Bang bang. I am. The warrior. |
#7 posted 06-25-2014 01:14 PM |
I think you should clarify… the saw was originally designed for 14” blades, correct? I can see someone stumbling across this thread who wouldn’t know any better trying to run a 12” or 14” blade in a 10” saw… -- Woodworking from an engineer's perspective |
#8 posted 06-25-2014 01:25 PM |
Yes the saw is a 14” saw. I have to change arbor extensions to use a 10” blade. If someone tried to put a 14” blade on a 10” saw, they would find the hole is way too big for their arbor. |
#9 posted 06-25-2014 02:48 PM |
How Did you fit the 10” blade to fit the (I assume )1” arbor? -- Ken from Ontario, Canada |
#10 posted 06-25-2014 02:54 PM |
No, my saw has interchangeable arbor extensions. They are stub shafts that screw into the end of the arbor shaft. I have to change them out the extensions when going from a 5/8” 10” blade to a 1” 14” blade. |
#11 posted 06-25-2014 03:00 PM |
Ken, many 12” + saws have replaceable arbors to go from 1” to 5/8”. Mark -- Tilbilly Mark |
Forum | Topics |
Woodworking Skill Share
12028 |
Woodturning
2106 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4904 |
6694 |
28055 |
CNC Woodworking
212 |
Hand Tools
5407 |
Jigs & Fixtures
1418 |
Wood & Lumber
6232 |
1388 |
Focus on the Workspace
2154 |
1186 |
Woodworking Trade & Swap
4756 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
