Garage Baseboard
Forum topic by uMinded posted 06-25-2014 01:03 AM 6847 views 0 times favorited 8 replies Add to Favorites Watch
View uMinded's profile
uMinded
115 posts in 1755 days
06-25-2014 01:03 AM
Topic tags/keywords: baseboard garage
I have finished my garage and am stumped when choosing how to finish the bottom drywall edge. I do not plan on getting my garage wet but i am sure it will around the doors during winter. My ideas:
1) Treated 2×4’s all around. Terribly ugly…
2) Std 2×4’s jointed, planned and stained. Culked to floor for a good seal.
3) Cedar fence boards (1×6 x 6’) ripped in half, planned and stained.
3) Residential MDF baseboard. Would swell terribly if it ever got wet. Looks great.4
Rubber base is crazy expensive for some reason but I only need to cover 70 linear feet.
8 replies so far
View Whiskers's profile
Whiskers
389 posts in 1930 days
#1 posted 06-25-2014 01:27 AM
Use standard wooden baseboards, not that finger jointed stuff, and paint with 1 coat of good exterior paint and follow with a gloss or simi gloss in floor/porch enamel. Paint both sides of the baseboard before installing, than touch up after installing. During installation, Put down a bead of silicon caulk and set your baseboard on top of it.You can than use a hose when needed to clean the floor without having to worry.
View BentheViking's profile
BentheViking
1782 posts in 2467 days
#2 posted 06-25-2014 01:32 AM
Where’d you look for rubber base?
I run a lumber liquidators store and we sell it for $0.89/LF. I know it adds up but it also doesn’t seem outrageous. With anything else I’d recommend (assuming your concrete is relatively even and level) leaving it like 1/16” off the ground. Enough to keep out of contact, but not enough to notice.
-- It's made of wood. Real sturdy.--Chubbs Peterson
View bobkberg's profile
bobkberg
439 posts in 2976 days
#3 posted 06-25-2014 04:05 AM
I was going to say part of what Whiskers did – so I’ll repeat it.
Anything that is going to be exposed to moisture should be sealed with a good primer/sealer on ALL surfaces (Zinsser 1-2-3, Kilz), 2 coats and let it dry thoroughly before putting in place.
-- Bob www.singularengineering.com - A sideline, not how I earn a living
uMinded
#4 posted 06-25-2014 04:09 AM
Rubber base was sold in 100’ rolls at the carpet suppliers for $160/roll which is quite steep. I can get 3” mdf baseboard for $0.39/foot
I think I will give it two coats of exterior as suggested and silicone them down too.
Whiskers
#5 posted 06-25-2014 05:08 AM
The standard wood or mdf baseboard sold in packs at the big box stores is pre-painted with a primer. The reason I suggest the method of painting I do is cause it is what I like to do. Floor enamel will eventually dry and harden to a super tough and hard finish, but it takes a while. Unfortunately it doesn’t stick as well as paint really should and is easily sloughed off if bumped by something before it adheres. It sticks much better to a already painted surface than it does to primers. That why I use first coat of exterior paint which is probably more than good enough, but than follow with the enamel to get that semi gloss look and hard water proof finish I desire.
View Redoak49's profile
Redoak49
3075 posts in 1891 days
#6 posted 06-25-2014 11:44 AM
In my shop, I used a 2×6 as a baseboard. I wanted something that could take a beating and be up high enough to prevent casters on tool bases from damaging the drywall. I found relatively straight 2×6 and then cut a 45° on the top corner and ran a couple of grooves on the face using my router table. This made them look much better than the plain 2×6. I finished them with the same stain and finish as the rest of the trim in my shop and attached them using deck screws into the studs.
When I have put up either plywood or drywall in a garage area, I keep it an inch or more above the floor. This keeps any moisture from getting up into it.
View MrRon's profile
MrRon
4627 posts in 3146 days
#7 posted 06-25-2014 04:50 PM
Hardie board. I used it outdoors under a covered patio. Caulked it and never a problem from water. Has been in place for 15 years now.
View WhyMe's profile
WhyMe
976 posts in 1464 days
#8 posted 06-25-2014 06:51 PM
Composite decking makes good water resistant base boards.
