Brushes - replaced - tiny holding tab not holding
Forum topic by Eastern posted 06-24-2014 11:16 PM 755 views 0 times favorited 4 replies Add to Favorites Watch
View Eastern's profile
17 posts in 1386 days
06-24-2014 11:16 PM
Hi all,
I just replaced 2 brushes (per a video) and the tiny tab that holds the brush/spring in place doesn’t hold. The brush goes back in place just fine.
Can I just install it with out the tiny holding tab holding the brush?
View hookfoot's profile
194 posts in 1885 days
#1 posted 06-24-2014 11:43 PM
Are they paint brushes or wire brushes. It might matter.
#2 posted 06-24-2014 11:53 PM
Carbon brushes for a table saw.
View Tim's profile
3760 posts in 1897 days
#3 posted 06-25-2014 12:17 AM
Brushes work by having that spring press the carbon against the motor. So you definitely need the part that holds the tab to be held at the right depth. I think the part with the tab is what completes the circuit so you really need that to have a solid connection too. It sounds like you got the wrong brushes or aren’t connecting the tab right. Pictures, brand/model number, etc might help.
View William Shelley's profile
William Shelley
557 posts in 1405 days
#4 posted 06-25-2014 07:52 AM
I would consider upgrading away from a table saw with a brushed motor… That being said, Tim is correct on this.
-- Woodworking from an engineer's perspective
