DIY Edge Lipping Planer
Forum topic by DangerDoug posted 06-24-2014 08:28 PM 2821 views 0 times favorited 3 replies Add to Favorites Watch
View DangerDoug's profile
DangerDoug
76 posts in 1846 days
06-24-2014 08:28 PM
Any folks build a DIY edge lipping planer?
Need to plane-down 3/4” x 7/8”+ poplar off a 3/4” plywood edge.
Found the Hoffman which is very nice, although a bit pricey.
Seems like this is a common task and there must be some DIY lipping tables or jigs that can be made with a mid-size router.
Any pics out there that can be posted would be great!
Thanks.
HOFFMAN LINK: http://hoffmann-usa.com/machinery/hebor-edge-lipping-planer/bh-556-lipping-planer-hebor
3 replies so far
DangerDoug
#1 posted 06-25-2014 05:09 PM
okay…had a little advice here :-|
Now looking for down cutting spiral bit.
DangerDoug
#2 posted 06-26-2014 12:34 AM
Success!
I wish somebody showed me this about 4 decades ago; all the years/time spent trying to make fast work out of this! Grumble!!!
The plan is easy – a 6” x 6” x 14” L shape with braces.
Add swing plate for router and a extra 1/2” “table” on bottom (aprox. 5”)
Will need to add a nice big handle and maybe vac fitting.
Had a $12 Yonico 14150 Straight Router Bit [1/2-Inch X 2-Inch Length 1/2-Inch Shank] which worked fine.
DangerDoug
#3 posted 06-30-2014 09:05 AM
This jig meets all my criteria – works pretty good for the low cost (or no cost).
Would certainly be handy for a plywood shelving project. Just lay the boards down and trim wood edges (3’ or longer)
This sample is a 24” long project [wood edge on plywood] used the DIY trimmer, super smooth, very little sanding.
