Bandsaw drift help
Forum topic by bdresch posted 06-24-2014 05:25 PM 1600 views 0 times favorited 35 replies Add to Favorites Watch
View bdresch's profile
bdresch
139 posts in 1510 days
06-24-2014 05:25 PM
I have been working this week on setting up my first bandsaw. Its a 14” cast iron Craftsman Professional model 22424 I got cheap on Craigslist. From everything I can tell it is identical to all the other import 14” bandsaws. The saw came with a 1/4” blade. It came with the Kreg bandsaw fence. I tore the whole thing apart to clean it and inspect it and took the opportunity to replace all the bearings. I also replaced the spring with a Carter Products high tension spring, since the original was slightly bent. Per suggestions on here, I watched the Alex Snodgrass bandsaw clinic video and attempted to setup the saw per his instructions. I squared the table and fence to the blade and tried making some cuts. I get between 4-5 degrees of drift. I then tried centering the blade on the wheel like the instruction manual says instead of centering the gullet like Snoddgrass says and I get about the same amount of drift. What could I be doing wrong? Is it maybe my blade? Should I ignore his instructions and co-planer the wheels? Any help would be appreicated.
35 replies so far
16272 posts in 4120 days
#1 posted 06-24-2014 05:37 PM
These are pretty elementary points, but:
a. Are your guide blocks properly adjusted?
b. Are you cutting with the minimum necessary amount of exposed blade?
c. Are you forcing the cut? Pushing too hard against a not-so-sharp blade could be the problem.
View Sanding2day's profile
Sanding2day
1008 posts in 1748 days
#2 posted 06-24-2014 05:38 PM
Am by far no expert but will tell you that I had initially experienced drift using a 1/4” blade and after switching to a 1/2” 3tpi blade for resawing had absolutely no issues what so ever. My guess is to try a larger newer blade anytime sharp curves are unnecessary.
-- Dan
bdresch
#3 posted 06-24-2014 05:52 PM
A. As far as I know. I installed Coolblocks and new thrust bearings. Everything is as close as possible without touching.
B. Yes. Only about 1/8 above a 4/4 piece of pine.
C. This was maybe my guess. It seems like I have to push harder than I would’ve expected to cut, but I haven’t touched a bandsaw since high school 15 years ago.
I think maybe I’ll stop at the hardware store tonight and pick up a new blade.
- CharlieM1958
View junebug's profile
junebug
100 posts in 2306 days
#4 posted 06-24-2014 05:54 PM
is the blade installed with the teeth pointing down?
I’m not going to say why I thought to check that….
View bondogaposis's profile
bondogaposis
4594 posts in 2253 days
#5 posted 06-24-2014 05:58 PM
My guess is your blade is dull. Put a new one in and see if there is a difference.
-- Bondo Gaposis
View jmartel's profile
jmartel
7687 posts in 2052 days
#6 posted 06-24-2014 06:01 PM
New blade, and buy a 1/2” 3tpi blade made for resawing. A 1/4” blade won’t do well with straight cuts.
View UpstateNYdude's profile
UpstateNYdude
912 posts in 1885 days
#7 posted 06-24-2014 06:16 PM
I love the Snodgrass method has been working awesome for me for the last few months like the others said try a new blade.
-- Nick, “I am always doing what I cannot do yet, in order to learn how to do it.” – Vincent Van Gogh
View b2rtch's profile
b2rtch
4847 posts in 2950 days
#8 posted 06-24-2014 06:19 PM
The blade must be dead center on the tires.
-- Bert
View Bill White's profile
Bill White
4853 posts in 3862 days
#9 posted 06-24-2014 07:30 PM
You’ve got a blade problem.
Correct tension, guides set, saw away.
I use some of the Snodgrass suggestions, but my Grizz works best with the blade, not the gullet, centered on the tire.
Just my results on a Grizz 0555LX 14” (no riser) with an aftermarket blade.
Bill
-- bill@magraphics.us
bdresch
#10 posted 06-24-2014 07:35 PM
Would a 3/8” be a good general blade? I plan to get a 1/2” when I need to do resawing, but I think my normal use will be crosscutting and cutting gradual curves in 4/4 hardwood and maybe a little plywood.
View ChefHDAN's profile
ChefHDAN
1010 posts in 2751 days
#11 posted 06-24-2014 07:47 PM
+1 for getting a good blade, I like the Timberwolf ones, doubt you’ll find them in most stores. Woodworker’s supply always seems to have good prices on them, average blades run from 12 to 20 bucks so don’t be afraid to get a few widths, there isn’t really a combo blade for the band saw, you’ll need different widths and TPI for what you plan to be cutting.
View jonah's profile
jonah
1570 posts in 3200 days
#12 posted 06-24-2014 08:37 PM
- b2rtch
Not according to Alex Snodgrass’s setup, which I have had fantastic luck with on my humble bandsaw.
https://www.youtube.com/watch?v=wGbZqWac0jU
View Surfside's profile
Surfside
3389 posts in 2075 days
#13 posted 06-24-2014 08:51 PM
If it’s not how you position the blade, then the problem is your band saw blade.
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
jmartel
#14 posted 06-24-2014 08:55 PM
Personally, I have a 1/4” and a 1/2” blade that I use and switch between depending on operation. The 1/2” stays on for the majority of the time, unless I need to cut tighter curves.
View Jim Finn's profile
Jim Finn
2612 posts in 2824 days
#15 posted 06-24-2014 10:20 PM
It is the blade!
showing 1 through 15 of 35 replies
