Once again I turn to fellow LJ's for help, inlaying coins into coasters.
Forum topic by Blackie_ posted 06-24-2014 03:21 PM 1297 views 0 times favorited 20 replies Add to Favorites Watch
View Blackie_'s profile
Blackie_
4879 posts in 2475 days
06-24-2014 03:21 PM
I was just commissioned to build four sets of coasters, 8 coasters per set, customer is also is wanting 3” dia military coins inlayed in each coaster, knowing that condensation will be on the coins, what method should I use to inlay them with? 2 part epoxy is what I’m thinking.
Thanks
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
20 replies so far
13600 posts in 3304 days
#1 posted 06-24-2014 03:29 PM
a dab of silicone should be just fine
the stuff is tenacious
and no mess to clean up
if you don’t overdo it
View Jamie Speirs's profile
Jamie Speirs
4168 posts in 2819 days
#2 posted 06-24-2014 03:32 PM
Randy, make the hole a wee bit bigger
mask the coin and wax the wood
then put a black silicone bed down
Push the coin down then smooth away the excess
with a wet finger
once dry the overcast is easily removed
This allows for a fair amount of movement in the wood
Hope this helps
Jamie
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
View bigblockyeti's profile
bigblockyeti
5086 posts in 1683 days
#3 posted 06-24-2014 03:36 PM
Two part epoxy would be my vote. It’ll keep the surrounding wood dry and the surface can be cleaned easily and polished if they get scratched up over time.
HillbillyShooter
5811 posts in 2255 days
#4 posted 06-24-2014 03:41 PM
This sounds like a question for LJ Klaus Keifer as he imbeds Canadian coins in many of his projects and they always look great. But, I’ve vote for 2-part epoxy and use masking tape over the area, removing the coin area with a knife so as to avoid epoxy on the wood surface. Best wishes.
View grizzman's profile
grizzman
7836 posts in 3266 days
#5 posted 06-24-2014 03:43 PM
i like jamie’s approach
-- GRIZZMAN ...[''''']
Blackie_
#6 posted 06-24-2014 05:14 PM
I am curious as to why Black silicone Jamie?
Thanks
View pintodeluxe's profile
pintodeluxe
5618 posts in 2776 days
#7 posted 06-24-2014 05:20 PM
Epoxy, silicone, or construction adhesive have all worked equally well for me. Silicone adhesive might be best with metal.
As far as the wood movement comment above… wood movement across a 3” coin is negligible.
Jamie Speirs
#8 posted 06-24-2014 08:59 PM
Randy that was the spec for a job I did many years ago
I think it shows a metal to wood nicely
I’m sure any colour would be nice
Jamie
grizzman
#9 posted 06-24-2014 09:12 PM
i like the color black as i think it would hide any of the circle that might not get covered by the coin, but hopefully you can make the opening for the coins very close to what is needed, having a very small amount as i dont think much would be needed, whatever wood species you use, i would imagine it to be very dry.
View Jim Jakosh's profile
Jim Jakosh
20270 posts in 3068 days
#10 posted 06-24-2014 09:24 PM
I usually rough up the back of a coin and use the HF 5 minute epoxy and it holds great.
View kiefer's profile
kiefer
5618 posts in 2630 days
#11 posted 06-25-2014 12:04 AM
I use a pressure fit on most of my coins with CA glue and the back of the coin rought up .
In your case because of the large size I would go with the epoxy but make the fit slightly loose .
The silicon idea sounds good the only problem I can see with it when the finish is applied and spots where there residue will fisheye .
-- Kiefer https://www.youtube.com/user/woodkiefer1/videos
View Roger's profile
Roger
20923 posts in 2767 days
#12 posted 06-25-2014 12:15 AM
Sounds like they’ll be really nice coasters. I’d think epoxy, but no matter what, you’ll still have moisture on the bottom of the cup and on the coaster. That said, I don’t know.. lol
Blackie_
#13 posted 06-25-2014 12:21 AM
ok I’m going to pick up both 30 min and fast drying along with the silicone , thanks .
View Sodabowski's profile
Sodabowski
2373 posts in 2796 days
#14 posted 06-25-2014 09:56 AM
I’d have said epoxy too but Jamie’s approach sounds very interesting, since the coins could still be removed later without too much hassle and risk.
-- Thomas - Pondering the inclusion of woodworking into physics and chemistry classes...
grizzman
#15 posted 06-25-2014 01:03 PM
randy, what type of wood are you using for your coasters, ive got a huge amount of wine corks that im trying to figure out if they would be used somehow in a coaster thing…have you ever seen any coasters made with corks in them
