Finish planing question
Forum topic by Jesse posted 06-23-2014 01:46 PM 865 views 0 times favorited 3 replies Add to Favorites Watch
View Jesse's profile
Jesse
58 posts in 1535 days
06-23-2014 01:46 PM
If I buy a Powermatic planer with spiral head and carbide inserts, how smooth can I get the board surface? I get my lumber planed by the lumber company right now but it comes with burn marks and snipe, so I want to plane my own if it will come out with a nice finish. Being able to take one pass through the drum sander after planing as opposed to the seven I have to do right now will be a big improvement and time and money saver but I don’t want to waste money on the planer if it is not going to give me the finish I want. Thoughts from those of you that use planers with spiral carbide cutting heads?
Thanks
3 replies so far
View bigblockyeti's profile
bigblockyeti
4994 posts in 1630 days
#1 posted 06-23-2014 02:17 PM
It’s very likely that you’ll be much better off doing your own planning. It sounds like your lumberyard is using a machine that hasn’t be properly maintained and possibly by someone who isn’t capable of reducing snipe with proper board support.
4885 posts in 2402 days
#2 posted 06-23-2014 02:34 PM
I have a Delta with carbide inserts, and after planing, it’s usually 2-3 passes (no more) with an ROS before the wood is ready for finish (I also hand sand with the grain lightly). I would say the finish from the Powermatic will be much nicer than the lumber yard job. Besides the planers being maintained in a less-than-perfect manner, they are doing one thing: making the board thinner; it doesn’t matter if the planing job is less than optimal. But to be honest, I didn’t think my drum sander leaves wood ready for finish either. Regardless, I think you will benefit from a planer.
View Todd's profile
Todd
398 posts in 1585 days
#3 posted 06-24-2014 09:08 PM
My Steel City helical head planer leaves a nice finish requiring minimal sanding with a ROS to remove any remaining tool marks.
-- Todd, Huntsville, AL
