My miter saw is getting stuck in the cutting position...!
Forum topic by ZUZI posted 06-22-2014 07:29 PM 8261 views 0 times favorited 21 replies Add to Favorites Watch
View ZUZI's profile
ZUZI
14 posts in 1876 days
06-22-2014 07:29 PM
Topic tags/keywords: miter saw kobalt blade guard stuck-down miter saw
This morning I made one cut on a 1×4 and the saw wouldn’t raise again. When I tried to force it back up, the only thing that happened was the blade guard came up. That was scary.
I made a video, to show and explain in greater detail. Wonder if anyone has run into this before, and what may be the cause and solution.
It is a Kobalt 10” sliding compound miter saw, we’ve had for 11 monts, and made much less than a total of 50 cuts on it.
Thanks, in advance, for any light you might shed on it.
I do plan on calling Customer Service tomorrow Monday.
Thanks again ~
Susie
-- ...what the...!
21 replies so far
View ZUZI's profile
ZUZI
#1 posted 06-22-2014 07:30 PM
Well duh——here is the link to the youtube video I made about the saw, this afternoon.
If anything isn’t clear, I’ll try to clarify.
https://www.youtube.com/watch?v=zuVAduMKN_s&feature=youtu.be
-- ...what the...!
View William Shelley's profile
William Shelley
576 posts in 1589 days
#2 posted 06-22-2014 08:07 PM
There’s usually a pin towards the back that locks the arm down for transporting. It’s possible that vibration caused it to engage.
-- Woodworking from an engineer's perspective
View Rayne's profile
Rayne
1026 posts in 1659 days
#3 posted 06-22-2014 08:29 PM
I’d say look in the manual for a complete parts breakdown of the saw and see how that bar is installed. It almost looks like there should be a washer or a spacer at the blade guard pivot point to keep it straight. Just a thought.
View AnonymousRequest's profile
AnonymousRequest
861 posts in 1668 days
#4 posted 06-22-2014 08:52 PM
At 2:30 on your clip it looks like your arm is bent, looking straight down along it. Put it in a vise and tweek it back.
View Tommy Evans's profile
Tommy Evans
148 posts in 2293 days
#5 posted 06-22-2014 09:01 PM
also at the 2:30 mark there is definite “click” sound, can you see what might be making that sound? It also seems to “jerk” at that point also.
Is it still under warranty?
View ZUZI's profile
ZUZI
#6 posted 06-22-2014 10:32 PM
The lock-down pin is right where it should be, so that’s okay. It doesn’t move when the saw is running.
The bar—it’s called simply “lever” in the parts breakdown—is held in place by the 2 large pan head silver screw only, no washers. The center screw that rides in that gullet has a cylinder sleeve that rides in the gullet, and a lock washer on the backside. I thought too that there must be a washer or spacer missing, but none are listed in the exploded view or list of parts.
The “click” sound is the arm/bar/lever “falling” to the left, and it “falls” from the rear end to the front end. The whole lever.
I thought of tightening those screws – they are immovable! On very very tight! So in that respect as far as removing the lever, and trying to straighten it, I don’t think I’d be able to do that.
It is 11 months old, almost 12 months, and the manual says there is a 3 year warranty. Bought at Lowes, July 2013.
I am really mystified as to how the lever bent, if it did bend.
-- ...what the...!
View changeoffocus's profile
changeoffocus
467 posts in 1737 days
#7 posted 06-22-2014 10:43 PM
I think Freddy called it, I would guess that chrome screw at the front is some manner of shoulder screw and is loose allowing the arm to slide behind the shoulder onto the thread. This in turn makes it twist.
Hope this helps.
View ZUZI's profile
ZUZI
#8 posted 06-22-2014 10:57 PM
I wish it was a loose screw. I tried to turn all three of the screws on the lever. They are all EXTREMELY tight.
I can’t tell if the lever is bent… Looking at it straight down the line, it doesn’t seem to be. It definitely ‘falls’ or ‘twists’ , hard to get the right word for it.
I have really liked this saw, it’s done an excellent job, and I’ve felt very comfortable using it. It’s a shame this happened. I was planning on cutting lots of 1×4s today….
I’ll be calling CS tomorrow, and I understand Lowes is very good about returns. I always use that “MyLowes” number they swipe when you buy something, so you don’t need a receipt. It remembers everything for you!
Like paint colors…. very handy. :-)
-- ...what the...!
changeoffocus
#9 posted 06-22-2014 11:11 PM
I have no doubt in Lowes integrity, it’s always fun to try and find out what causes something and avoid the hassle of return.
If you were use a smooth jawed adjustable open end (Crescent wrench) and twist that arm as someone else suggested I doubt anyone would notice if it did not fix the problem.
It’s a pain when an equipment malfunction interrupts one’s plan.
View ZUZI's profile
ZUZI
#10 posted 06-22-2014 11:22 PM
You’re right Bob—I’ll try that in the morning. Can’t hurt. And I totally agree about finding out the WHY and HOW.
If stuff didn’t fail, I’d never learn how to fix things !
I’ll let y’all know how it goes, or if I do have to return it, and what happens.
I really appreciate the replies, and the suggestions!
-- ...what the...!
View ZUZI's profile
ZUZI
#11 posted 06-23-2014 01:48 PM
Well, I just got off the phone with Kobalt’s customer service. Explained the problem. Very nice fellow, asked me a question about the pivot nut (that central one in the slot/gullet) and I told him about the video I made would show it better than I can explain it.
Turns out, that lever and the lower blade guard raising with it been has been a problem “that has been plaguing them for quite a while” and that my video may have solved it. They’re sending the link to the supplier of the lever. Which has already been changed to make it stronger. . . . hmmmmm.
So the supplier is send a new lever, and I’ll have to replace it.
I asked Kobalt if my prize was a nice router/table combo… “ha ha ha”. Well, if you don’t ask!
I suppose I could have just swapped it out at Lowes, but I think this might be better. More interesting, anyway. And less strain. And I’m going to see how this original lever lays flat and straight, or bent, when I swap them out.
Again, thanks for all your advice and comments. I never would have got here otherwise.
-- ...what the...!
View bigblockyeti's profile
bigblockyeti
5206 posts in 1840 days
#12 posted 06-23-2014 02:02 PM
It’s surprising that they’d still have that on the market while trying to remedy a serious design flaw. I’d say that your video solving their problem would be worth a little more than just a router table. The liability they’ve assumed when the first person is injured with their faulty design could very easily be in the millions of dollars!
Tommy Evans
#13 posted 06-23-2014 02:14 PM
yeah, good point yeti, especially since the blade guard unexpectedly raises when trying to lift the handle.
now, zuzi you’ll have to bust loose those ”...immovable; very,very tight” bolts! FUN.
glad it’s all going to work out for you. build on!
View ZUZI's profile
ZUZI
#14 posted 06-23-2014 02:37 PM
-- ...what the...!
View LoyalAppleGeek's profile
LoyalAppleGeek
160 posts in 1014 days
#15 posted 12-14-2015 10:51 PM
I also have this issue with the Kobalt 10-Inch Sliding Compound Miter Saw. I was able to temporarily reduce the friction by putting a washer in between the bar and the mount plate on the screw furthest at the back. I contacted Kobalt (Lowes) as well and am waiting for a response.
