Face frame questions
« back to Joinery forum
Forum topic by woodworkingdrew posted 06-22-2014 05:59 PM 2119 views 0 times favorited 11 replies Add to Favorites Watch
View woodworkingdrew's profile
woodworkingdrew
190 posts in 1602 days
06-22-2014 05:59 PM
I have two questions.
1. What methods are out there for attaching face frames to the carcuss
2. Is it common practice to leave a 1/4 inch overhang on the face frame?
-- Andrew, California
11 replies so far
View RockyTopScott's profile
RockyTopScott
1186 posts in 3472 days
#1 posted 06-22-2014 07:13 PM
1. I dado FF and glue, but looking at spline more now
2. I think so
-- “When you want to help people, you tell them the truth. When you want to help yourself, you tell them what they want to hear.” ― Thomas Sowell
View MT_Stringer's profile
MT_Stringer
3168 posts in 3225 days
#2 posted 06-22-2014 08:10 PM
1) For kitchen style cabinets, I use pocket screws and apply a skin on the finished ends if it will show. When I built, the buffet, I didn’t have to skin anything. On mom's cabinets, I attached a mdf panel to the end next to the refrigerator.
Same for Shelley's wet bar.
2) The 1/4 inch allows the installer room to scribe the cabinet to the wall if necessary.
View Sawdust4Blood's profile
Sawdust4Blood
404 posts in 3015 days
#3 posted 06-22-2014 11:31 PM
I either use pocket screws or biscuits. First choice is pocket screws by a large margin because they are a lot easier than getting the alignment perfect on the biscuits. Only advantage to the biscuits is they are completely hidden without having to skin over.
I typically make my overhang about an 1/8th unless I think that I will need to scribe to a wall. You definitely want to leave at least an 1/8 even if you aren’t scribing because that little gap between cabinets also lets you adjust for walls that aren’t completely flat and still have the faces look right.
-- Greg, Severn MD
View English's profile
English
655 posts in 1471 days
#4 posted 06-23-2014 01:48 AM
I use pocket screws, Glue and Biscuits, I really don’t want them to come off
-- John, Suffolk Virgina
MT_Stringer
#5 posted 06-23-2014 02:03 AM
“I use pocket screws, Glue and Biscuits, I really don’t want them to come off”
John, have you ever tried to remove a face frame after the glue dries? I have. I removed all of the pocket screws and couldn’t beat the frame off without busting it up. I finally gave up. :-(
English
#6 posted 06-23-2014 02:14 AM
No, I have never had a need to, but if I did I would just build a new box. They are not coming off.
woodworkingdrew
#7 posted 06-23-2014 02:26 AM
MT- I read and heard somewhat the same thing. I think its very effective to just use glue alone.
MT_Stringer
#8 posted 06-23-2014 02:37 AM
“No, I have never had a need to, but if I did I would just build a new box. They are not coming off.”
That is exactly what I had to do.
View DLCW's profile
DLCW
530 posts in 2648 days
#9 posted 06-26-2014 01:51 AM
For attaching faceframes to carcasses, I use biscuits mainly for alignment. Modern glues will hold a faceframe to a carcass very well. I’ve experimented and have found I can’t break a faceframe from a REAL plywood carcass. MDF, melamine or particle board carcasses are a different story. Easy to break the faceframe from the carcass. So I guess the answer here is, it depends on your carcass material.
For cabinets mounted side by side I use 1/16” faceframe overlay. For cabinets that will butt against a wall, the amount of overlay depends on well the kitchen walls were done. If done well, I will leave 3/16”. If done the ussual way, I will leave 1/4”. For end cabinets, I will leave either 3/16” or 1/4” on the side so that cabinet can be scribed to the wall.
I have customers that don’t want this level of sophistication (read price) in their installation, so I will have a simple 1/16” overlay on faceframes and use scribe molding to fill any gaps. Scribe molding, for those who don’t know what it is, is a 3/4” wide x 1/8” thick piece of faceframe stock that is applied using a pin nailer. The pin is virtually invisible. Customer saves money and it still looks very nice.
-- Don, Diamond Lake Custom Woodworks - http://www.dlwoodworks.com - "If you make something idiot proof, all they do is make a better idiot"
View Todd's profile
Todd
398 posts in 1670 days
#10 posted 06-26-2014 11:06 PM
If it is a shop cabinet I use pocket screws, unless it will be painted then I just use glue and an 18g brad nailer. For nicer stuff I use the Sommerfeld Tongue and Groove set:
Which is what I used on this nightstand.
Click for details
-- Todd, Huntsville, AL
View RogerM's profile
RogerM
792 posts in 2393 days
#11 posted 06-27-2014 01:36 PM
Ditto on the Sommerfield’s Own (tongue and groove) system. I have used this system for at least 4 years and love it.
With respect to the overhang question I do both. Leave an overhang on a set of wall cabinets that will be butted to each other or one that needs to be coped to a wall. Make them flush for furniture or free standing pieces. The Sommerfield’s Own system will easily accomplish both.
-- Roger M, Aiken, SC
