Why are my cuts so horrible?
Forum topic by Scootles posted 06-21-2014 03:29 AM 1336 views 0 times favorited 14 replies Add to Favorites Watch
View Scootles's profile
153 posts in 1847 days
06-21-2014 03:29 AM
I’m cutting 1/8” BB plywood at 45” angles and they are HORRIBLE cuts… Does anyone know why? I am using the stock blade… As steady as I am, my cuts have a ‘curve’ to them. No 2 cuts match up. When held against a straight edge the middle touches, but the 2 edges don’t… :(
14 replies so far
View jmartel's profile
7741 posts in 2082 days
#1 posted 06-21-2014 03:41 AM
A miter or a bevel cut? Sounds like you aren’t using steady pressure or they are sliding a bit.
View NoThanks's profile
798 posts in 1461 days
#2 posted 06-21-2014 03:41 AM
Sounds like your not keeping the wood totally flat as your making the cut.
-- Because I'm gone, that's why!
#3 posted 06-21-2014 04:08 AM
I’m using my tablesaw, and its slightly warped. I was thinking glue-ups would solve the problem with the warped wood.
I’m ready to toss in the towel. Without the top notch machinery I had when I worked in a cabinet shop, all I can make is trash… :-/
View ColonelTravis's profile
1748 posts in 1826 days
#4 posted 06-21-2014 04:45 AM
Top notch machinery is going to have a problem with warped wood, too. Two things come to mind, although I’ve never done it with 1/8 ply, so maybe these won’t help.
Thing 1 – dampen the bowed side, lay that side face down on your driveway or floor or patio or something that gets a lot of sun or warmness. Being summer now should make this easy, unless you’re an Aussie. The concave side is the part that lost moisture, so you’d be adding it there while taking some out of the humped side, resulting in movement toward straightness again.
Thing 2 – Not sure what the size of your plywood is when you cut it, but you could clamp it underneath a heavy board so it’s straight and cut them both, which would give you a straight cut, but when you unclamp it it will still be warped. Maybe during your glue-up you could eliminate that via your clamps and be fine. Not sure, but I have looked at many sheets of it before and always seen warped pieces in the pile somewhere. Seems to be sort of common with that stuff.
View Paul's profile
721 posts in 1497 days
#5 posted 06-21-2014 04:50 AM
1/8” plywood? Getting close to veneer size there as is. Thin plywood wants to warp around itself, cutting it by itself is a losing battle if you have had it in your shop for a while already. When ever I buy 1/4” ply for a project I plan on cutting and using it the same day I get it.
Depending on the end result of said 1/8” ply using a sacrificial 3/4” ply backer on top will help make cleaner cuts. 3/4” ply is much more expensive however.
Just a note of caution cutting warped anything in the table saw ups the anti on a kick back happening.
View waho6o9's profile
8130 posts in 2509 days
#6 posted 06-21-2014 04:54 AM
A block plane should clean it up.
View Paul's profile
#7 posted 06-21-2014 05:00 AM
I’ve never had any luck with a block plane on the edges of plywood without terrible chip out. Care to elaborate a bit more on your process on planing plywood edges?
#8 posted 06-21-2014 12:48 PM
Maybe cut a couple pieces of scrap at 45 degrees and sandwich
the plywood in between and plane away the problem areas.
Shouldn’t take much.
A wicked sharp blade is beneficial.
View Buckethead's profile
3194 posts in 1800 days
#9 posted 06-21-2014 01:00 PM
Wicked shaaahp cures all. Plane. It. Flat.
-- Support woodworking hand models. Buy me a sawstop.
View InstantSiv's profile
262 posts in 1527 days
#10 posted 06-21-2014 01:07 PM
Try putting masking tape on both sides of where the cut will be. I got the same results with 1/4” ply and figured I would try masking tape next time I needed to cut thin ply.
View ajosephg's profile
1880 posts in 3493 days
#11 posted 06-21-2014 09:32 PM
I’d recommend an 80 tooth cross cut blade as well.
-- Joe
View TheFridge's profile
9079 posts in 1418 days
#12 posted 06-21-2014 09:41 PM
That’s what she said.
View Ted's profile
2838 posts in 2143 days
#13 posted 06-21-2014 09:43 PM
If you have a router of any sort, cut it square then get your 45 with the router. A router table would be best but if you don’t have that, mount or rig a fence to your router. You may have to deal with preventing chip out by scoring with a utility knife first, or mounting a sacrificial piece… whatever it takes. Basically, use the table saw to get the straight cut, but use some other method to get the 45.
-- You can collect dust or you can make dust. I choose to make it.
View Dallas's profile
3599 posts in 2419 days
#14 posted 06-21-2014 09:55 PM
Put weight on when cutting to make it flat, you can fix it later.
You can also cut 1/8” with a knife and a straight edge that is going to give you a lot better cut.
