BLO + Turpentine
Forum topic by siavosh posted 06-21-2014 01:35 AM 1357 views 0 times favorited 7 replies Add to Favorites Watch
View siavosh's profile
siavosh
674 posts in 1834 days
06-21-2014 01:35 AM
A couple simple questions:
1. What’s the benefit of mixing Turpentine with BLO?
2. What ratio would you recommend for softwoods (sugar pine, Alaskan yellow cedar)?
Thanks!
-- http://woodspotting.com/ -- Discover the most interesting woodworking blogs from around the world
7 replies so far
View gfadvm's profile
gfadvm
14940 posts in 2653 days
#1 posted 06-22-2014 12:21 AM
It smells really nice (if you like the small of turpentine).
I mix my BLO with equal parts mineral spirits to hasten cure/drying.
View srzsrz's profile
srzsrz
37 posts in 1830 days
#2 posted 06-22-2014 08:19 AM
Turpentine is just a solvent, so you’re diluting the BLO; it’s going to mostly flash off. Personally I hate the smell of traditional turpentine, and I much prefer “odorless mineral spirits,” which seems to work just fine.
Anyway, I could see why you’d dilute varnish. Most brushing varnishes make good wiping varnishes if you dilute them about 1:1, and generally diluted varnish is easier to apply without streaks and brushmarks.
But with Boiled Linseed Oil, or any other true oil finish (not “Danish Oil” which is actually an oil/varnish blend), it’s hard to mess up anyway. There’s absolutely no problem in applying too much of it, since you get about an hour to wipe off the excess before it really starts setting up. If it really does dry faster when it’s diluted, that might be a good thing, but I suspect you’d also end up effectively applying less of it each time and needing to oil more often before the wood really saturates.
4949 posts in 2456 days
#3 posted 06-22-2014 11:15 AM
I cut my straight BLO with MS (don’t care for the smell of turp, though I have used it) simply to make it a little easier to handle. It flows on better and wipes of easier. But I only apply one coat for color/grain enhancement….I never use it as a the finish, and I never put on more than one coat.
View Clint Searl's profile
Clint Searl
1533 posts in 2324 days
#4 posted 06-22-2014 12:05 PM
BLO is only good for starting fires, but the turps will get it burning faster. Nyuk nyuk
siavosh
#5 posted 06-22-2014 01:11 PM
Thanks folks. So turpentine doesn’t help absorption of the oil into the wood?
#6 posted 06-22-2014 02:17 PM
No it doesn’t, though that’s a common assumption.
View Fuzzy's profile
Fuzzy
298 posts in 3951 days
#7 posted 06-22-2014 09:15 PM
“BLO is only good for starting fires, but the turps will get it burning faster. Nyuk nyuk”
- ClintSearl
My thoughts exactly … you beat me to it … ... ...
-- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ...
