Table question
Forum topic by Mark posted 06-20-2014 10:48 PM 775 views 0 times favorited 1 reply Add to Favorites Watch
View Mark's profile
892 posts in 1906 days
06-20-2014 10:48 PM
Afternoon all. When building a table top, am I correct in assuming that if it’s a 1 piece top, then the boards run parallel with the sides c/w bread boards.? And if it has extensions for adding leaves then the boards run parallel to the ends? Thanks.
-- Mark
1 reply so far
View Mark Kornell's profile
Mark Kornell
1169 posts in 2462 days
#1 posted 06-21-2014 12:54 AM
Yes, usually the boards are oriented so they run the long dimension of the table. But there’s no reason not to have them running in the short dimension – you just need to factor in significant wood movement in the long direction.
And breadboard ends are optional. They serve two purposes – hide end grain and help in keeping a top flat. Obviously, hiding end grain is purely an aesthetic decision and even if a top needs help in staying flat, there are other ways to accomplish that.
-- Mark Kornell, Kornell Wood Design
